Installing to Raspbian "buster"
bugmenot
Post by bugmenot » Tue Jun 25, 2019 6:33 am
Now that Raspbian is Debian “buster” based, could you give for newbies installaton instructions. Thanks
Re: Installing to Raspbian "buster"
Post by bbunge » Tue Jun 25, 2019 2:35 pm
Procedure on the WIKI for Debian should work. Am installing the new Raspbian to test. Stay tuned...
Post by bbunge » Tue Jun 25, 2019 6:36 pm
Become root
sudo su
apt install mariadb-server mariadb-client php php-mysql apache2 libapache2-mod-php
mysql_secure_installation
Edit sources.list
nano /etc/apt/sources.list
For Pi uncomment:
deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free$
Ctrl+o Enter to save
Ctrl+x to exit
Update apt
apt update
Install Zoneminder
apt install zoneminder
chmod 740 /etc/zm/zm.conf
adduser www-data video
For Pi, Create Zoneminder database in Mariadb (Note: this also creates the default Zoneminder user and permissions in MySQL)
mysqladmin -uroot -p reload
Start Zoneminder
a2enmod cgi
a2enmod rewrite
a2enconf zoneminder
Add timezone to PHP
sed -i "s/;date.timezone =/date.timezone = $(sed 's/\//\\\//' /etc/timezone)/g" /etc/php/7.3/apache2/php.ini
Restart Apache
service apache2 restart
bugmenot
Post by bugmenot » Wed Jun 26, 2019 5:02 am
When i do
i get error:
E: Unable to locate package zoneminder
Post by bbunge » Wed Jun 26, 2019 8:58 pm
Edit sources.list
For Pi uncomment:
Note: It the above is not exactly as shown in the sources.list file just uncomment the last line in the file. By uncomment I mean remove the # and the following space.
Ctrl+x to exit
Update apt
apt update
bugmenot
Post by bugmenot » Thu Jun 27, 2019 10:24 am
Thanks. That helped.
Now when i do
it asks password and no matter what i put there, raspberry password or return or password created during mysql_secure_installation, i always get empty row. Cursor just goes to start of next row.
Post by bbunge » Sat Jun 29, 2019 1:06 am
Now when i do
Not sure what you mean by "empty row"
The password is the database password entered when you secured the database.
the command "mysql -uroot -p < /usr/share/zoneminder/db/zm_create.sql" will prompt you for the database password, will appear to do nothing for up to a minute or so then return to the command prompt. Just keep going through the procedure.
pms
Post by pms » Sat Aug 24, 2019 4:11 pm
Thanks for your Excellent manual how to install Zoneminder!
I am a first time user /installer and was wondering about the password for user 'zmuser'.
I used 'zmpass' as you mentioned in the doc.
Should I have used a unique password or is this OK?
(can't remember if I had to enter this password in the configuration of ZM somewhere later)
Thanks!
PMS
