Modect always in Capturing mode
harrypale
Post by harrypale » Sat Jun 01, 2019 10:11 am
Hello, I have installed ZoneMinder 1.32.3 on Ubuntu 18.04.2 LTS following this shell script.
The only problem I have and I cannot figure it out, is that in all modes, even in Modect mode (except in None), with 0 zones, ZM is still in Capturing mode but it doesn't really create event files (it creates video files only if I force alarms).
I have to monitor only this IP camera. If I disable it, it shows:
Modect, disabled
Capturing
I tried to reinstall ZoneMinder or delete and re-add the camera, but no luck.
Before, I had an HDD with same OS and it was fully working. I bought an SSD and installed all from zero, but I have only this problem.
Thank you
harrypale
Re: Modect always in Capturing mode
Post by harrypale » Sun Jun 02, 2019 9:27 am
I have formatted and reinstalled Ubuntu server 18.04.2 LTS and reinstalled ZM from zero, but the same problem.
I think it's a bug, but I didn't find no one with the same problem.
ckilner
Post by ckilner » Sun Jun 02, 2019 1:36 pm
That's correct I believe. All modes apart from "None" are capturing. Capturing doesn't necessarily mean recording.
