Storage view shows not full memory capacity
markush
Post by markush » Sun Apr 21, 2019 9:00 am
currently I'm using Zoneminder 1.32.3 on Ubuntu 18.04. For the recording I'm using a extra harddisk with 4 TB. I have created a storage in the options dialog, it shows the following:
Bildschirmfoto vom 2019-04-21 10-29-15.png (5.69 KiB) Viewed 926 times
Why doesn't it show the full size of the disk for the storage? :?:
Re: Storage view shows not full memory capacity
Post by iconnor » Sun Apr 21, 2019 3:19 pm
a 4TB disk is probably measured in thousands instead of 1024's.
markush
Post by markush » Mon Apr 22, 2019 7:08 am
I know, thats not my problem. What i mean was the information: "186.58GB of...". Why does the system only use 186.58 GB instead of the full 3.58TB? The complete hdd is empty! What's on if the 186.58GB used for recordings? Actually there are round about 600MBs used for recording...
Thanks!
kitkat
Post by kitkat » Mon Apr 22, 2019 11:23 am
I'd expect a 4 TB drive to show somewhere in the region of 3.6 TB, so that part looks about right.
If this is a Linux system running an ext2/3/4 file system then the 'used space' could very well be the OS Reserved Blocks - This is typically 5% by default, which is close to the 180 GB showing as used on your drive.
You can see how much space is reserved (in blocks) with
dumpe2fs -h /dev/sda1
(change /dev/sda1 to whatever your drive is called)
You can set the amount of reserved space with
tune2fs -m 0.5 /dev/sda1
The value is in percent so the 0.5 represents one-half of one percent. Zero is acceptable, but may not be recommended.
markush
Post by markush » Mon Apr 22, 2019 2:38 pm
Ah okay, that sounds realistic! And dumpe2fs shows the following:
dumpe2fs 1.44.1 (24-Mar-2018)
Filesystem volume name:   <none>
Last mounted on:          /video
Filesystem UUID:          7c888137-d8ce-4d1a-b87b-5d4f04b0f66f
Filesystem magic number:  0xEF53
Filesystem revision #:    1 (dynamic)
Filesystem features:      has_journal ext_attr resize_inode dir_index filetype needs_recovery extent 64bit flex_bg sparse_super large_file huge_file dir_nlink extra_isize metadata_csum
Filesystem flags:         signed_directory_hash
Default mount options:    user_xattr acl
Filesystem state:         clean
Errors behavior:          Continue
Filesystem OS type:       Linux
Inode count:              244195328
Block count:              976754385
Reserved block count:     48837719
Free blocks:              960943943
Free inodes:              244192933
First block:              0
Block size:               4096
Fragment size:            4096
Group descriptor size:    64
Reserved GDT blocks:      1024
Blocks per group:         32768
Fragments per group:      32768
Inodes per group:         8192
Inode blocks per group:   512
Flex block group size:    16
Filesystem created:       Sat Apr 13 12:53:09 2019
Last mount time:          Mon Apr 22 10:48:04 2019
Last write time:          Mon Apr 22 10:48:04 2019
Mount count:              32
Maximum mount count:      -1
Last checked:             Sat Apr 13 12:53:09 2019
Check interval:           0 (<none>)
Lifetime writes:          60 GB
Reserved blocks uid:      0 (user root)
Reserved blocks gid:      0 (group root)
First inode:              11
Inode size:               256
Required extra isize:     32
Desired extra isize:      32
Journal inode:            8
Default directory hash:   half_md4
Directory Hash Seed:      148807e4-9184-42c4-8d9d-a3a4d9626110
Journal backup:           inode blocks
Checksum type:            crc32c
Checksum:                 0x52d6ee7a
Journal features:         journal_incompat_revoke journal_64bit journal_checksum_v3
Journal size:             1024M
Journal length:           262144
Journal sequence:         0x000012bb
Journal start:            1
Journal checksum type:    crc32c
Journal checksum:         0x2e8b0cb8
It's an ext4 Linux (Ubuntu 18.04). Thanks!
