Upgraded my system a little while ago to 1.32.3.
I've noticed since then that my linked monitors will randomly stop recording. Restarting ZM from the console will restore the functionality.
I have a handful of cameras, most of which supply a low-def and hi-def stream. ZM is set to Modect on the low-def stream (low res, low fps) and if motion is detected, the linked monitor (high res, higher fps) which is set to Nodect but linked to the low-res should record.
I haven't nailed down a time-frame yet as to how long it works as intended before it stops. My system is for home use and it normally just runs in the background and I only look at it if I need to review some video.
I previously ran 1.30.4 and had no problems. Anyone else experiencing this issue? If so, have you found a solution?
