Hi together,
i need some help, after my homeserver vg group was crashed, i have to install it new from scratch, because i had forgot to take a backup from my configurations...
So I have installed Ubuntu Server 18.04, with zoneminder 1.32.3, i have used the following guides.
Install - https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
dedicated drive - https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
email conf - https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
My old own was an installation with zoneminder 1.29.x and upgrade to the latest one and runs without such problems, but the freshly new installation get me in some trouble.
My problem, i am at step to create an email filter under menu filters. (see attachments - zm_mail_filter), then when i click on list matches or execute,
then i will get an empty overview without events and in the log file i see SQL errors (see attachments - zm_sql_error).
Kind Regards
create filter for email notification - SQL ERROR
- zm_sql_error.png (198.43 KiB) Viewed 1071 times
- zm_empty_result.png (15.62 KiB) Viewed 1071 times
- zm_mail_filter.png (34.54 KiB) Viewed 1071 times
Re: create filter for email notification - SQL ERROR
IS is not what you want. It is really only used for testing for NULL. You want Equals.
Hi iconnor,
that's it. it works. thanks.
