Page 1 of 1
Source Type: Web Site
Posted: Sat Feb 02, 2019 5:01 pm
by goofy
Hello everybody.
I'm running two Zoneminder installations, location1 and location2, version 1.32.3.
I'm trying to add a camera from location2 at location1, using Source Type: Web Site, Function: Monitor.
Using the follwing: https://ip-addr:port/zm/cgi-bin/nph-zms?mode=jpeg&monitor=1&user=usr&pass=pwd
This does work from any browser.
When I save these settings, Source Type goes back to Local!
Seems impossible to do this!
Anyone tried this?
Best regards
Rune
Re: Source Type: Web Site
Posted: Sat Feb 02, 2019 9:41 pm
by bbunge
Do you have them set up as multi server?
You also need to tell us your Linux distro and version.
Posted: Sat Feb 02, 2019 10:08 pm
by goofy
Hi
No, they are running both as single servers.
I'm running Lubuntu 18.04 on both.
Posted: Wed Feb 06, 2019 4:38 am
by Pedulla
I don't get this on my UB18.04 zm1.32.3 setup.
The monitor stays as website.
Posted: Fri Feb 08, 2019 7:17 pm
by goofy
Strange, I've tried this on both installations, same thing happen.
Did a fresh 1.32.3 install on one of them, since I upgraded from 1.32.2 to 1.32.3,
but same thing happen....
Posted: Sat Feb 09, 2019 2:51 am
by rockedge
in this case using a similar setup I found using the remote method captures another ZM system's monitor stream very well.
So not the "Web Site" method but the "Remote" method and then a path like
/cgi-bin/nph-zms?scale=100&width=320px&height=240px&mode=jpeg&maxfps=30&monitor=3&auth=06f91479b0cf8d51baf69d4ab0a317d0
you might have to set Options->Systems->AUTH_RELAY to "none" on the ZM system you are grabbing the stream from
Posted: Sun Feb 10, 2019 12:08 pm
by goofy
Hi, thanks for your suggestion. I've tried this, but this method only support HTTP and RTSP.
I need to use HTTPS to access the server/camera.
