zm/api/monitors.json failing!!
himalaya
Post by himalaya » Sat Jan 19, 2019 4:21 pm
Recently installed 1.32.2 and it looks like I've got api configuration issues as I am unable to get to work from a browser (first discovered there was an api issue when attempting to access via ZMninja pro). No clue as to where to look for resolving this.
Re: zm/api/monitors.json failing!!
Post by bbunge » Sat Jan 19, 2019 7:02 pm
Linus distro and version?
k-sudak
Post by k-sudak » Sat Feb 16, 2019 7:26 pm
I have the same problem on v1.30.4 started on Raspberry Pi 3B (Raspbian-Stretch distributive)
"http://server/zm/api/host/getVersion.json" shows me empty page :(
Post by bbunge » Sun Feb 17, 2019 1:53 pm
Zmninja works well with Zoneminder on a Pi with Raspbian. Make sure you use the Debian 9 install instructions, updated 17FEB19 for Pi, on the WIKI. Also set the correct paths in Zmninja.
