ZmNinja does not play event footage
sodisuhy
Post by sodisuhy » Thu Jan 17, 2019 4:23 pm
hello all...
i am running Zonminder 1.32.3 on Ubuntu 18.04 and LAMP. here is the installation guide i used to install:
here is also a list of the things i did before and after the Zoneminder installation
https://docs.google.com/document/d/1K7o ... sp=sharing
i noticed after the installation and subsequent configuration of Apache that i can no longer play event footage in ZmNinja. i am using hashed logins and have the API enabled. i can view the footage from the events without any issue if i view them via the Apache web site.
here are a few pictures of what i see in ZmNinja:
https://drive.google.com/file/d/1U_NCW4 ... sp=sharing
https://drive.google.com/file/d/1NGkS-q ... sp=sharing
the last time i installed ZM on Ubuntu 17.10, this worked without any real interaction on my part.
what am i missing? any thoughts are appreciated.
SkippyDo
Re: ZmNinja does not play event footage
Post by SkippyDo » Thu Jan 17, 2019 5:36 pm
Check your cameras' resolution.
Here's a thread on this (NOTE: this issue should be addressed within the apps forum section as it really only seems an issue with apps/smart phones):
viewtopic.php?f=33&t=27840
Users browsing this forum: Google [Bot] and 11 guests
