Hello.
My English is not good, so
I have ZM 1.32.2, Ubuntu 18.04.
Connect 1 camera and set to record.
In "Monitor" settings Misc tab set 'section length' to 1800.
I have that error in log
Camera 1: 17646 - Closing event 134, section end forced zm_monitor.cpp
And my event records is not 30 mins, they randomly drops record and start again.
What should I do to fix that?
Event record stops forced
- Screenshot 2018-11-16 at 08.54.53.png (656.72 KiB) Viewed 3641 times
Re: Event record stops forced
Did you try shorter events?
I stick to 10 mins (600) on my continuous record.
30 mins seems like a really big recording to have to manage.
Yes, I tried, but it didn't help.
In the daytime recording events in parts of 900 seconds, in the nighttime the events begins stop records randomly.
Any ideas?
Any ideas?
I have also seen such behaviour in my zm server in some cases.
Could you please provide infos about: your monitor settings, i.e. source tab settings and storage tab settings?
Sometimes event record drops with that error
Sometimes with - Camera 1: 17646 - Closing event 134, section end forced zm_monitor.cpp
Monitor buffer settings
I attach my monitor settings (general, source, storage)
2018-11-22 18:32:15 zma_m1 24205 INF Camera 1: image_count:836 - Closing event 1283, shutting down zm_monitor.cpp 643
2018-11-22 18:32:15 zmdc 24223 INF 'zmc -m 1' started at 18/11/22 18:32:15 zmdc.pl
2018-11-22 18:32:15 zmdc 17692 INF 'zmc -m 1' starting at 18/11/22 18:32:15, pid = 24223 zmdc.pl
2018-11-22 18:32:15 zmdc 17692 INF Starting pending process, zmc -m 1 zmdc.pl
2018-11-22 18:32:14 zmdc 17692 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2018-11-22 18:32:14 zmc_m1 20856 FAT Maximum number (25) of JPEG errors reached, exiting zm_jpeg.cpp 43
2018-11-22 18:32:14 zmc_m1 20856 ERR Invalid JPEG file structure: two SOI markers zm_jpeg.cpp 40
2018-11-22 18:32:12 zmfilter_2 19994 INF Checking filter Update DiskSpace update disk space returned 0 events zmfilter.pl
2018-11-22 18:32:11 zmfilter_1 19981 INF Checking filter PurgeWhenFull delete returned 0 events zmfilter.pl
2018-11-22 18:31:25 zmc_m1 20856 INF Camera 1: images:167000 - Capturing at 4.50 fps, capturing bandwidth 935136bytes/sec zm_monitor.cpp 2473
2018-11-22 18:31:12 zmfilter_2 19994 INF Checking filter Update DiskSpace update disk space returned 0 events zmfilter.pl
2018-11-22 18:31:11 zmfilter_1 19981 INF Checking filter PurgeWhenFull delete returned 0 events zmfilter.pl
2018-11-22 18:30:12 zmfilter_2 19994 INF Checking filter Update DiskSpace update disk space returned 1 events zmfilter.pl
2018-11-22 18:30:11 zmfilter_1 19981 INF Checking filter PurgeWhenFull delete returned 0 events zmfilter.pl
2018-11-22 18:30:09 zma_m1 24205 INF Camera 1: 287 - Opening new event 1283, section start zm_monitor.cpp 1482
2018-11-22 18:30:08 zmc_m1 20856 WAR Last image read from shared memory 8 seconds ago, zma may have gone away zm_monitor.cpp 2442
2018-11-22 18:30:08 zmc_m1 20856 WAR Buffer overrun at index 15, image 166655, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 2437
2018-11-22 18:30:04 zmc_m1 20856 WAR Buffer overrun at index 15, image 166635, slow down capture, speed up analysis or increase ring buffer size zm_monitor.cpp 2437
Image Buffer Size (frames) 20
Warmup Frames 0
Pre Event Image Count 0
Post Event Image Count 5
Stream Replay Image Buffer 0
Alarm Frame Count 1
- 1general.png (63.55 KiB) Viewed 3562 times
- 2source.png (60.93 KiB) Viewed 3562 times
- 3storage.png (52.6 KiB) Viewed 3562 times
