Console shows incorrect event counts
I am trying to get Zoneminder running in a docker container, and I've had this instance up for a few weeks now... I just noticed that the event counts listed on the Console are the same for each time period. What weird configuration have I enabled? Or is this a bug?
- Screenshot 2018-09-13 14.14.00.png (58.85 KiB) Viewed 40181 times
Re: Console shows incorrect event counts
This would be a misconfig I think. I suspect that either a db update failed or zmstats.pl is not running.
I see the same thing. It uses lxc to proxmox. After upgrading to 1.31
How would one go about making sure that `zmstats.pl` runs automatically in the docker instance? Or how to start it manually?
