Page 1 of 1
Camera compatibility
Posted: Tue Nov 14, 2017 2:17 pm
by Nicolas_LesPaul
Hi there,
I'm on the verge of beginning a project student, my aim is to make face/human recognition in a kitchen through a camera.
I will use various pythons libs like OpenCV and dlib to make the recognition but I first need to collect image.
Every camera collect data through its app, and send data to the cloud. However, I want to collect data directly on my PC in order to compute it on the spot.
I have 2 questions:
1) May you confirm me that ZoneMinder will help me collecting data from the IP camera Yi Dome Camera 1080p ?
2) If this cam doesn't appear to be the best choice for human detection in a kitchen because it doesn't work or dunno why, what would you advise me to buy (I have a budget of 150 euros) please ?
Thanks in advance,
Nicolas.
Re: Camera compatibility
Posted: Wed Nov 15, 2017 2:13 am
by snake
If you can get the ONVIF discovery program to tell you the RTSP path, it should work. I read the Yi Dome camera is ONVIF compatible. However, I don't see other people using it, so it should work, but not guaranteed.
See ispy and the forums. You are on your own.
https://www.ispyconnect.com/man.aspx?n=xiaomi
viewtopic.php?f=36&t=26187
Also read the user manual of Yi for the RTSP / MJPEG paths. A good camera will tell you the path in the manual.
2) If this cam doesn't to be the best choice for human detection in a kitchen because it doesn't work or dunno why, what would you advise me to buy (I have a budget of 150 euros) please ?
See the https://wiki.zoneminder.com/Hardware_Compatibility_List.
Do you need IR? Do you need pan/rotate? What resolution? What FPS? All these questions must be considered.
Posted: Wed Nov 22, 2017 10:13 am
by Nicolas_LesPaul
Hi Snake,
Thank's for you feedback!
What we need is:
- A fix camera;
- We need to shoot only in one direction;
- The cam has a motion detector;
- Movies and pics are recorder in the computer;
- Resolution: 3264x2448;
- Sector alimentation;
- Budget of 150 euros;
Posted: Fri Feb 21, 2020 12:18 pm
by starkgene
I can also share the facial recognition package with the NVR software which I used for my cameras.
Check this tutorial by oZoneDev on Medium and synced with other tasks: DIY Doorbell face recognition with ZoneMinder and dbell projects and
