I made a fresh zonminder installation on my PI3
connected a simple usb camera and an IP camera .
I have 2 problems:
1. I lose signal to both camera , when I check zonminder onc a day to see events
I see that he say the cameras are offline , not recording events (the source is in red)
after I reboot the pi , is start to work for a few hours then - the same problem.
2. when he record the event is doesn;t record good , the image get stuck , and I can see that he "jump" 2-3 seconds
so in a 10 seconds record (this is waht he say I have ) - Ican only see 4 images
*** the IP camera is not off line , and no body is touching the USB (they are allways connected)
when I open the log I see
I used this cameras for half a year without any problem with the same PIWAR buffer overrun at index x , image xxx ,slow down capture ,speed up analysis or increasing ring buffer size
what could be the reason ?
I don;t rememer did any special setting
maybe something is f@!k with the SD card?
Thanks,
