from the official docs
https://zoneminder.readthedocs.io/en/la ... g-monitors
The camera we are using as an example here is a Foscam 9831W which is a 1280x960 RTSP camera, and the URL to access it’s feed is username:password@IPADDRESS:PORT/videoMain
I am currently trying to add a Tp-Link NC450. According to viewtopic.php?t=25757
Password: !! Your passwords base64 encoded version !!
This is what I am trying user=test password=test (dGVzdA==)
But when I try and save that I get an error.
If I leave it off - blue screen and log shows authentication error
I can use this directly in a browser
http://192.168.1.133:8080/
it prompts me for a user:pass - and then works
This is the first time I am trying base64 password in the URL like this. Searching the wiki was not much help.
Anyone please ....
how to add base64 password?
Re: how to add base64 password?
Try source type ffmpeg. Also verify the URL stream in VLC and when it works in VLC check the actual resolution. Be advised that hi res cams can run the server out of memory in tmpfs.
I have never used ffmpeg. Where does the user/pass go?
I am afraid I am going to run out of memory, but that is a different issue. Not there yet .. at least I don;t think so .. based on the log errors.
Oh wait - I found
Source Type: cURL (HTTP(S) only)
learnt something new!
Thanks bbunge you nudged me in the right direction.
It works now using the admin user and base64 password for admin. The test user does not work, but that's ok - I just made it because I was having problems.
