how to use new user?
david1234
Post by david1234 »
Hello ,
I have added a new user called "Viewer" with password "1234".
but how to use it?
my server is on 10.0.0.70
so when I open localhost - it doesn't ask me for password
when I enter using another computer in the netwrok - still I'm getting the admin page (with all the option)
so how to enter the server as viewer only?
Thanks ,
Re: how to use new user?
david1234 wrote: Wed Jul 03, 2019 7:49 am Hello ,
but how to use it?
Thanks ,
Did you enable OPT_USE_AUTH? Before you do make sure you know the admin password or set a user with system edit ability.
david1234
Post by david1234 »
I didn't enable it
didn't enter the setting menu at all...
is there a way to know the admin password? I don't think I cahnge it or been ask to enter it at any time
(so even if I create a new "admin" user , I don't wnat to leave the old "admin" if it's a default password)
Thanks .
david1234 wrote: Tue Jul 09, 2019 7:04 am I didn't enable it
Thanks .
While you are adding users just change the admin password before enabling OPT_USE_AUTH.
