ZoneMinder 1.30.4 & zmeventnotification : missing Python scripts
Oliv59
Post by Oliv59 » Sun Feb 10, 2019 8:21 pm
Hello there,
After fighting for a few hours with zmeventnotification and zmninja (desktop, windows 10), i end up with an irresolvable - at least for me - issue.
I run the 1.30.4 version on a rasp pi 3 under raspbian.
I setup the zmeventnotification, which finally loads fine.
I launch it through cli (via sudo -u www-data /usr/bin/zmeventnotification.pl, to fix the bugs, and then i'll launch the daemon), it works apparently fine, but when i force an alarm, i see those logs :
Invoking hook:'/usr/bin/detect_wrapper.sh' 68 2 "Garage" "Forced Web"
Traceback (most recent call last):
  File "/usr/bin/detect_yolo.py", line 24, in <module>
    import configparser
ImportError: No module named configparser
Previously, i had :
Invoking hook:'/usr/bin/detect_wrapper.sh' 66 2 "Garage" "Forced Web"
  File "/usr/bin/detect_yolo.py", line 18, in <module>
    import cv2
ImportError: No module named cv2
I fixed this cv2 issue with "sudo apt-get install python3-dev libmysqlclient-dev"
But, for the ConfigParser issue, i couldn't find any valuable solution :(
Moreover, i'm pretty surprised all those scripts are missing ? Wouldn't I more missing something ?
Thanks for any help on this, i'm almost done with this setup, i'd like to watch this work !
Oliv.
Oliv59
Re: ZoneMinder 1.30.4 & zmeventnotification : missing Python scripts
Post by Oliv59 » Tue Feb 12, 2019 10:29 pm
In case someone passes here, and want to have the fix, here it is :
https://github.com/pliablepixels/zmeven ... /issues/80
TL;DR : Either disabling the hooks in zmeventnotification.ini (adding a # before the hook path), or running sudo pip -r requirements.txt from the hook folder (didn't work in my case, pip command not found).
