How to upgrade from 1.30 to 1.XX under Raspbian / Debian ?
Oliv59
Post by Oliv59 » Sat Feb 09, 2019 5:41 pm
Hello here,
I might bu dumb (or still asleep), but despite a lot of researches, i couldn't manage to find how to update from 1.30 to 1.32 or 1.33 my zoneminder setup, running un a rasp pi under raspbian.
Is there a simple way ?
Thanks for your help :D
Olivier.
Re: How to upgrade from 1.30 to 1.XX under Raspbian / Debian ?
Post by bbunge » Sun Feb 10, 2019 1:09 pm
Have not been able to do that yet with Debian. Have run 1.32.3 on Mate 18.04 on Pi 3B+.
snake
Post by snake » Sun Feb 10, 2019 5:58 pm
In an RPI3, If you have Raspbian, you can change to the Debian repos and upgrade to experimental where ZM 1.32.2 is. I haven't done an upgrade from Raspbian, but export the DB and reimport it in, and it "should work". I do know that a fresh install works.
Instructions can be found in https://wiki.zoneminder.com/Raspbian
Raspbian has only I think 1.30.0 ZM in the repo, while Debian has 1.30.4 in its stable repos. So if you are unsure about the process, it might be best to wait until 1.32+ is in the stable repos of Raspbian / Debian.
Oliv59
Post by Oliv59 » Sun Feb 10, 2019 8:05 pm
OK, thanks. Will wait for stable versions of 1.32+ (i also saw a 1.33 ?)
Thanks for your explanation :)
