No errors, "capturing", but no image.
Posted: Sun Feb 03, 2019 5:11 pm
Greetings:
First of all, sorry if this has been asked before.
After a lot of searching (not knowing quiet well how) I didn't find any solution (neither a similar situation).
It is simple, Logs does not show any problem (AFAIK), but in the View page, no image shows up.
Neither ffmpg nor libvlc (other options shows errors).
VLC works fine with the same URL.
Fresh Debian 9 install.
Zoneminder 1.30.4
Paths fixed.
Permission for DB zm's user forced.
All over LAN (no port issues).
The first line keep increasing by 1000 every minute and a half or so.
Any clue why?
Any other log I could check?
Thanks.
Zoneminder 1.30.4
Paths fixed.
2019-02-03 17:46:07.245596 zmc_m2 788 INF HOSTNAME: 1000 - Capturing at 11.49 fps zm_monitor.cpp 3125
2019-02-03 17:44:41.082405 zmc_m2 788 INF Priming capture from rtsp://username:password@IP:PORT/PATH zm_ffmpeg_camera.cpp 104
2019-02-03 17:44:41.046486 zmc_m2 788 INF Starting Capture version 1.30.4 zmc.cpp 247
2019-02-03 17:44:40.576950 zmdc 733 INF 'zmc -m 2' starting at 19/02/03 17:44:40, pid = 788 zmdc.pl
2019-02-03 17:44:40.576950 zmdc 788 INF 'zmc -m 2' started at 19/02/03 17:44:40 zmdc.pl
2019-02-03 17:44:40.539660 zmdc 733 INF Starting pending process, zmc -m 2 zmdc.pl
2019-02-03 17:44:40.498690 zmdc 733 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2019-02-03 17:44:38.885670 zmfilter 773 INF Scanning for events zmfilter.pl
2019-02-03 17:44:38.568090 zmwatch 783 INF Watchdog pausing for 30 seconds zmwatch.pl
2019-02-03 17:44:38.495370 zmwatch 783 INF Watchdog starting zmwatch.pl
2019-02-03 17:44:38.077280 zmdc 733 INF 'zmwatch.pl' starting at 19/02/03 17:44:38, pid = 783 zmdc.pl
2019-02-03 17:44:38.074700 zmdc 783 INF 'zmwatch.pl' started at 19/02/03 17:44:38 zmdc.pl
2019-02-03 17:44:37.675920 zmdc 777 INF 'zmaudit.pl -c' started at 19/02/03 17:44:37 zmdc.pl
2019-02-03 17:44:37.659580 zmdc 733 INF 'zmaudit.pl -c' starting at 19/02/03 17:44:37, pid = 777 zmdc.pl
2019-02-03 17:44:37.238810 zmdc 773 INF 'zmfilter.pl' started at 19/02/03 17:44:37 zmdc.pl
2019-02-03 17:44:37.238800 zmdc 733 INF 'zmfilter.pl' starting at 19/02/03 17:44:37, pid = 773 zmdc.pl
2019-02-03 17:44:36.843630 zmdc 769 INF 'zmc -m 2' started at 19/02/03 17:44:36 zmdc.pl
2019-02-03 17:44:36.843630 zmdc 733 INF 'zmc -m 2' starting at 19/02/03 17:44:36, pid = 769 zmdc.pl
2019-02-03 17:44:36.503510 zmpkg 718 INF Single server configuration detected. Starting up services. zmpkg.pl
2019-02-03 17:44:33.494540 zmdc 733 INF Server starting at 19/02/03 17:44:33 zmdc.pl
2019-02-03 17:44:32.741690 zmpkg 718 INF Command: start zmpkg.pl
2019-02-03 17:44:32.667660 zmpkg 718 INF Sanity checking States table... zmpkg.pl
Thanks.
