Camera falls-off due to "RTSP timed out" and doesn't go back
Posted: Tue Jan 29, 2019 3:47 pm
I have ZM v1.30.4 running from a docker container and TENVIS camera. It's connected as:
It works in motion detection mode.
Right after adding it works fine, but after couple of hours camera became red and monitor didn't show anything. If I just open settings window and press "Save" without changing anything it starts to work again. ZM restart also helps.
In logs I see:
What brings me to idea that TENVIS cam becomes unresponsive from time to time and during this "outage" zm marks it as bad. Is it possible to increase this time-out threshold? Or force ZM to retry to connect to bad cameras regularly?
Remote Protocol Remote
Method RTP/RTSP
Remote Host Name admin:xxxxxxxx@192.168.1.127
Remote Host Port 554
Remote Host Path /11
Target colorspace
Capture Width (pixels) 640
Capture Height (pixels) 352
In logs I see:
2019-01-29 09:24:56.995850 zmc_m1[14350].ERR-zmc.cpp/312 [Failed to pre-capture monitor 1 718285028 (1/1)]
2019-01-29 09:24:56.493700 zmc_m1[14357].ERR-zm_rtsp.cpp/729 [RTSP timed out]
