how to setup to recieve stream from raspberry pi
4bf9gSBj
Post by 4bf9gSBj » Fri Jan 25, 2019 5:02 pm
i have version 1.3.4 installed from the stretch packages on a pc running amd64 kernel. i am using a raspberry pi zero w with the noir camera to send a stream with "raspivid -v -t 0 -n -b 2000000 -g 30 -ih -pf high -w 960 -h 720 -fps 30 -l -o tcp://192.168.2.70:8554". i can play the stream with "mplayer -fps 300 -demuxer h264es ffmpeg://tcp://192.168.2.70:8554". i have not found documentation for setting this up in zoneminder. any suggestions are appreciated.
Re: how to setup to recieve stream from raspberry pi
Post by bbunge » Sat Jan 26, 2019 2:44 am
If you can stream the camera with VLC use the same string and resolution in ZM with ffmpeg. It will work but you may have to play with the settings.
4bf9gSBj
Post by 4bf9gSBj » Sat Jan 26, 2019 12:18 pm
cvlc tcp/h264://192.168.2.70:8554 is able to play the stream. if i use tcp/h264://192.168.2.70:8554 as source path in zoneminder the log shows "Unable to open input tcp/h264://192.168.2.70:8554 due to: No such file or directory". if i use h264://192.168.2.70:8554 as source path the log shows "Unable to open input h264://192.168.2.70:8554 due to: Success". in both instances there is no connection to the pi zero.
4bf9gSBj
Post by 4bf9gSBj » Sat Jan 26, 2019 4:19 pm
i got it to work using tcp://192.168.2.70:8554 as source path but i can not get more than about 5 frames per second. i set raspivid to 30 fps and zoneminder to 300 fps. in the monitor it shows 30 fps but it appears to be about 5 fps
Post by bbunge » Sat Jan 26, 2019 8:12 pm
ZM is a security camera system not HD movie maker! 5 FPS should be sufficient. Max FPS in Zoneminder settings is for local cameras and that setting should be blank.
fatboy
Post by fatboy » Sun Feb 17, 2019 9:55 pm
For 10 years I've been running 15fps.
