zoneminder crashes frequently
rdorsch
Post by rdorsch »
since a few days, zoneminder crashes frequently (2-3 times/hour). The output of
systemctrl status zoneminder is
zoneminder.service - ZoneMinder CCTV recording and surveillance system
   Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2018-11-17 20:44:38 CET; 23s ago
     Docs: http://zoneminder.readthedocs.org/en/latest/
  Process: 22745 ExecStop=/usr/bin/zmpkg.pl stop (code=exited, status=1/FAILURE)
  Process: 8772 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
 Main PID: 9347 (code=exited, status=4)
Nov 17 20:44:32 home zma_m4[10459]: INF [Got signal 15 (Terminated), exiting]
Nov 17 20:44:32 home zma_m2[10141]: INF [Got signal 15 (Terminated), exiting]
Nov 17 20:44:32 home zmc_m3[10265]: INF [Got signal 15 (Terminated), exiting]
Nov 17 20:44:32 home zma_m1[28494]: INF [Got signal 15 (Terminated), exiting]
Nov 17 20:44:32 home zmc_m4[10408]: INF [Got signal 15 (Terminated), exiting]
Nov 17 20:44:32 home zma_m3[19097]: INF [Got signal 15 (Terminated), exiting]
Nov 17 20:44:32 home zmc_m2[17319]: INF [Got signal 15 (Terminated), exiting]
Nov 17 20:44:35 home zma_m1[28494]: INF [Cam0: 608 - Closing event 88214, shutting down]
Nov 17 20:44:38 home systemd[1]: zoneminder.service: Unit entered failed state.
Nov 17 20:44:38 home systemd[1]: zoneminder.service: Failed with result 'exit-code'.
Does status=4 tell something?
When I grep for ERR in syslog, I get
Nov 17 19:46:21 home zmwatch[31532]: ERR [Error getting last capture time for  Cam2]
Nov 17 19:47:14 home zmwatch[31532]: ERR [Error getting last capture time for  Cam2]
Nov 17 19:47:33 home zma_m3[15329]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542480449.876458, 'zma_m3', 0, 15329, 0, 'INF', 'Analysis fps (2.00) is lower than capturing fps (31.42), disabling adaptive
skip feature', 'zm_monitor.cpp', 889 )) error(Lost connection to MySQL server during query)]
Nov 17 19:47:43 home zmwatch[31532]: ERR [Error getting last capture time for  Cam2]
Nov 17 19:51:37 home zmc_m2[2483]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542480691.540434, 'zmc_m2', 0, 2483, 0, 'INF', 'Priming capture from rtsp://admin:Inei5wuu@cam1/Streaming/Channels/2', 'zm_ffm
peg_camera.cpp', 104 )) error(Lost connection to MySQL server during query)]
Nov 17 19:55:25 home zmdc[22232]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 19:55:27 home zmdc[22232]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 19:55:29 home zma_m2[23206]: ERR [Shared data not initialised by capture daemon for monitor Cam1]
Nov 17 19:55:29 home zmdc[22232]: ERR ['zma -m 2' exited abnormally, exit status 255]
Nov 17 19:55:30 home zmdc[22232]: ERR ['zmc -m 3' exited abnormally, exit status 255]
Nov 17 19:55:32 home zmdc[22232]: ERR ['zmc -m 4' exited abnormally, exit status 255]
Nov 17 20:12:02 home zma_m2[23267]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542481917.237972, 'zma_m2', 0, 23267, 0, 'INF', 'ExtendAlarm count: 13, ExtendAlarm frames: 15', 'zm_zone.cpp', 184 )) error(
Nov 17 20:12:54 home zmwatch[23776]: ERR [Error getting last capture time for  Cam1]
Nov 17 20:13:21 home zmwatch[23776]: ERR [Error getting last capture time for  Cam1]
Nov 17 20:13:57 home zma_m3[23357]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542482033.334940, 'zma_m3', 0, 23357, 0, 'INF', 'ExtendAlarm count: 0, ExtendAlarm frames: 2', 'zm_zone.cpp', 184 )) error(Lo
Nov 17 20:16:26 home zmdc[20503]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 20:16:54 home zmdc[20503]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 20:20:14 home zmdc[9347]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 20:20:16 home zmdc[9347]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 20:20:18 home zmdc[9347]: ERR ['zmc -m 3' exited abnormally, exit status 255]
Nov 17 20:20:20 home zmdc[9347]: ERR ['zmc -m 4' exited abnormally, exit status 255]
Nov 17 20:35:37 home zmwatch[10678]: ERR [Error getting last capture time for  Cam0]
Nov 17 20:36:12 home zmwatch[10678]: ERR [Error getting last capture time for  Cam0]
Nov 17 20:36:49 home zmwatch[10678]: ERR [Error getting last capture time for  Cam0]
Nov 17 20:37:55 home zmwatch[10678]: ERR [Error getting last capture time for  Cam0]
Nov 17 20:38:30 home zmwatch[10678]: ERR [Error getting last capture time for  Cam0]
Nov 17 20:44:29 home zmwatch[10678]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist.  zmc might not be running.]
Nov 17 20:46:25 home zmdc[30908]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 20:46:30 home zmdc[30908]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 20:46:44 home zmdc[30908]: ERR ['zmc -m 3' exited abnormally, exit status 255]
Nov 17 20:46:53 home zmdc[30908]: ERR ['zmc -m 4' exited abnormally, exit status 255]
Nov 17 20:47:00 home zma_m4[3636]: ERR [Shared data not initialised by capture daemon for monitor Cam3]
Nov 17 20:47:00 home zmdc[30908]: ERR ['zma -m 4' exited abnormally, exit status 255]
Nov 17 20:50:15 home zmdc[19780]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 20:50:17 home zmdc[19780]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 20:50:20 home zmdc[19780]: ERR ['zmc -m 3' exited abnormally, exit status 255]
Nov 17 20:50:22 home zmdc[19780]: ERR ['zmc -m 4' exited abnormally, exit status 255]
Nov 17 21:02:35 home zmc_m1[20284]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542484952.701707, 'zmc_m1', 0, 20284, -1, 'WAR', 'Buffer overrun at index 14, image 10964, slow down capture, speed up analysis or increase ring buffer size', 'zm_monitor.cpp', 3094 )) error(Lost connection to MySQL server during query)]
Nov 17 21:02:36 home zmdc[19780]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 21:02:56 home zmwatch[21146]: ERR [Error getting last capture time for  Cam0]
Nov 17 21:09:56 home zmdc[19780]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 21:10:17 home zmc_m2[12481]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542485412.329454, 'zmc_m2', 0, 12481, 0, 'INF', 'Priming capture from rtsp://admin:Inei5wuu@cam1/Streaming/Channels/2', 'zm_ffmpeg_camera.cpp', 104 )) error(Lost connection to MySQL server during query)]
Nov 17 21:10:34 home zmwatch[21146]: ERR [Memory map file '/dev/shm/zm.mmap.2' does not exist.  zmc might not be running.]
Nov 17 21:11:10 home zmdc[19780]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 21:12:29 home zma_m1[12791]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542485545.447368, 'zma_m1', 0, 12791, 0, 'INF', 'Cam0: 1098 - Gone into prealarm state', 'zm_monitor.cpp', 1689 )) error(Lost connection to MySQL server during query)]
Nov 17 21:12:32 home zmwatch[21146]: ERR [Error getting last capture time for  Cam1]
Nov 17 21:19:24 home zmwatch[21146]: ERR [Error getting last capture time for  Cam2]
Nov 17 21:19:48 home zmwatch[21146]: ERR [Error getting last capture time for  Cam2]
Nov 17 21:20:29 home zmwatch[21146]: ERR [Error getting last capture time for  Cam2]
Nov 17 21:20:49 home zmwatch[21146]: ERR [Error getting last capture time for  Cam2]
Nov 17 21:23:38 home zmwatch[21146]: ERR [Error getting last capture time for  Cam1]
Nov 17 21:24:06 home zmwatch[21146]: ERR [Error getting last capture time for  Cam1]
Nov 17 21:25:30 home zmwatch[21146]: ERR [Memory map file '/dev/shm/zm.mmap.2' does not exist.  zmc might not be running.]
Nov 17 21:25:36 home zmdc[19780]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 21:25:49 home zmwatch[21146]: ERR [Error getting last capture time for  Cam1]
Nov 17 21:26:16 home zmwatch[21146]: ERR [Error getting last capture time for  Cam1]
Nov 17 21:27:58 home zmdc[19780]: ERR ['zmc -m 3' exited abnormally, exit status 255]
Nov 17 21:28:54 home zmwatch[21146]: ERR [Error getting last capture time for  Cam2]
Nov 17 21:29:33 home zma_m2[24032]: ERR [Can't insert log entry: sql(insert into Logs ( TimeKey, Component, ServerId, Pid, Level, Code, Message, File, Line ) values ( 1542486566.976145, 'zma_m2', 0, 24032, 0, 'INF', 'ExtendAlarm count: 14, ExtendAlarm frames: 15', 'zm_zone.cpp', 184 )) error(Lost connection to MySQL server during query)]
Nov 17 21:31:06 home zmdc[12701]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 21:35:18 home zmdc[2564]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Nov 17 21:35:19 home zmdc[2564]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 21:35:21 home zmdc[2564]: ERR ['zmc -m 3' exited abnormally, exit status 255]
Nov 17 21:35:25 home zma_m3[3417]: ERR [Shared data not initialised by capture daemon for monitor Cam2]
Nov 17 21:35:25 home zmdc[2564]: ERR ['zma -m 3' exited abnormally, exit status 255]
Nov 17 21:35:26 home zmdc[2564]: ERR ['zmc -m 4' exited abnormally, exit status 255]
Nov 17 21:54:24 home zmdc[2564]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Nov 17 21:54:43 home zmwatch[3808]: ERR [Error getting last capture time for  Cam1]
Nov 17 21:58:15 home zmdc[2564]: ERR ['zmc -m 3' exited abnormally, exit status 255]
Any hint or advice is welcome....
Rainer
SkippyDo
Re: zoneminder crashes frequently
Post by SkippyDo »
Stating what hardware and OS you're running would help...
Seems that the source of the problem might be with MySQL. I'd look for logs associate with it (since I have no idea what system I cannot point you where to look). This is about the limit of my "knowledge."
You might be running out of connections to mysql. Or mysql might be going away for other reasons. Check mysql logs
