I want to setup a filter that will delete anything that is over 10 days old and low alarm frames. Maybe start doing this ones disk usage is over %75?
Preferably, Start with the lowest alarm frames and work its way up. Although a set number of alarm frames and less will work also.
I've tried and most of my combinations come up blank. Anyone out there know how I could setup a filter like this?
Trying to setup a Filter
Re: Trying to setup a Filter
Did you read: https://zoneminder.readthedocs.io/en/st ... vents.html
There are a lot of things you can do with filters. I use two: Purge older than 30 days and purge over 85% disk full.
Looking at the Alarm Frames value you may be able to: Alarm Frames Less than or equal to 100 and Date less than or equal to -10 day and Archive Status Unarchived only
You may need to write the 100 (or whatever usu choose) as -100
Keep in mind a "day" event may not run until after midnight unless you run it manually.
Thank you! Although I did try these setting before and it did not work, It worked this time.
I did not need to use the -100 which is odd. But ultimately it work!
Thanks again!
Thanks again!
I was able to setup with Filter. If I Submit or Execute the filter, It shows events. But it never automatically runs. I have it running at %80 disk full and I am at %82... Nothing gets deleted.
Here is a screen shot...
//imgur.com/a/wQh7U8K
add the http.
I also tried
//imgur.com/a/7RTMbjz
Still nothing.
add the http.
I also tried
Still nothing.
