Multipart MJPEG stream not working
spynet
Post by spynet » Wed Sep 19, 2018 9:52 pm
I'm trying to setup a monitor to handle a multipart mjpeg stream.
If I use what I think it should be the correct configuration, I can't see anything on the monitor and no event is recorded:
protocol = HTTP
host = 192.168.1.6
port = 8080
path = video/mjpeg
If I use ffmpeg with same parameters, it doesn't work either.
path = http://192.168.1.6:8080/video/mjpeg
The connection to the camera is effective, the camera is streaming but the log continue to display the message:
zma_m1 26445 WAR Waiting for capture daemon zm_monitor.cpp 503
Can somebody help?
Thanks.
spynet
Re: Multipart MJPEG stream not working
Post by spynet » Wed Sep 19, 2018 9:56 pm
One more information...
Just using the above URL in Firefox or Chrome on the same host running ZoneMinder I can see the stream natively with no issue.
Thanks again.
Post by bbunge » Wed Sep 19, 2018 11:45 pm
What about using VLC?
Double check the resolution you are using. That is the biggest cause for video to fail in Zoneminder.
spynet
Post by spynet » Thu Sep 20, 2018 8:45 pm
Do you mean libvlc? If so, it doesn't work but I'm not sure on how to set its parameters. VLC itself works perfectly.
I have tried different resolution without success.
In ZoneMinder 1.31.47, ffmpeg works but Remote does not.
spynet
Post by spynet » Thu Sep 20, 2018 10:18 pm
I found the problem: the mjpeg stream should contain the Content-Length header for each new frame, that is strange since the frame size should be detected based on the boundary tag.
Now I can see the stream but I have to set the image with 2 pixels less than the real or I'll get a skewed image. For example, with 640x480 image resolution, I need to set width=638, height=480. It seems to be true for all the resolutions.
Do somebody know why?
I'm testing with 1.31.47 now.
Users browsing this forum: No registered users and 9 guests
