Zoneminder 1.30.4 on 32 bit Ubuntu Bionic 18.04 i386
Post by bbunge » Wed Aug 29, 2018 7:55 pm
I have created a Zoneminder 1.30.4 install package for 32 bit or i386 Ubuntu 18.04. The links to the install package are:
https://173.163.189.225/zoneminder-1.30 ... c-i386.deb
or
wget --no-check-certificate https://173.163.189.225/zoneminder-1.30 ... c-i386.deb -P /tmp/
or
https://drive.google.com/file/d/1cgPOr2 ... sp=sharing
As of this writing I have not modified the install procedure located in the WIKI: https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
The install steps are the same just use the above links to get the zoneminder-1.30.4-bionic-i386.deb install package.
I have tested this on a fresh install of Bionic i386 server with an IP camera and a local USB camera. Also tested the API with Zmninja.
Re: Zoneminder 1.30.4 on 32 bit Ubuntu Bionic 18.04 i386
Post by rockedge » Wed Aug 29, 2018 11:22 pm
Nice! Excellent work bbunge
installing it tonight!
marineboss
Post by marineboss » Thu Sep 13, 2018 4:31 pm
Thank you for creating this, I need to create a server for a non profit group I am involved in, so I am using an old laptop but was going to have to create one, saved me a ton of time
Post by bbunge » Thu Sep 13, 2018 5:21 pm
That is how I got involved with Zoneminder. Worked with a faith based not-for-profit that refurbs PC's. They needed a security camera system, I had been learning Linux at work and played with Zomeninder. Still with them after 10 years. All but one PC in my home is 2nd hand. Even the cameras I use to test are 2nd hand. Have a very nice iMac from 2011. All this because I give my time back to them to keep their network running and safe! Think this is what Bush #41 meant with his thousand points of light.
New version 1.32.0 should be on the PPA soon!
vspriyan
Post by vspriyan » Wed Jan 09, 2019 3:47 am
The link given for installation procedure is not available anymore. But I need this zm version for my 32-bit Ubuntu Bionic 18.04. Any suggestions pls...
Post by bbunge » Mon Feb 18, 2019 2:17 am
