Crash / Burn / Recover - Can I?
AnotherBrian
Post by AnotherBrian »
I want to generate a video from zoneminder archive data on a trashed ubuntu 17.04 / zoneminder 1.30 system.
I can't boot up the drive and stupid me didn't use a logical drive system - everything is in a boot partition.
17.04 is no longer supported by ubuntu and there is a warning around that warns against using 17.10.
Okee Doke - one step back and now I got 16.04 / 1.30 running on a new drive.
Is there any way to get to the old archived data and generate a video? I would think mounting the old mysql/apache/zoneminder directories over the new system directories would be dangerous
Re: Crash / Burn / Recover - Can I?
That should work fine actually.
I feel the tricky part would be the zm database. I've used backup copies (dump) of the database to reinstall Zoneminder on a fresh system. I suppose it is possible to copy the MySQL zm files (located in /var/lib/mysql) to another drive. Not sure what you would have to do to get the database to work. Keep copies! Copy the /var/cache/zoneminder/*.* as well. Keep copies!! Remember if something goes wrong with the database the events records and/or images will be deleted. Keep Copies!!!
Ubuntu 17.04 should be still out there if you need to create a recovery disk. You may want to try to recover the existing drive. Make a copy if it can be read. Clonezilla may be able to transfer everything to another drive and if Clonezilla can read the old drive it can be used to make an image you can restore if your copies get messed up.
Did I say to make copies????
Best of luck... Of course you know Google is your friend...
AnotherBrian
Ok - this worked. User ids and Group Ids on the defective drive won't match the conventions on the new drive. mount --bind comes to mind but this won't work with ext4 system. Hence bindfs is the tool to use. Recall we have a new live drive with a new working zoneminder and we have an old drive with the data. We want the new zoneminder to use the old data.
First mount the drive. I used the gui from disks which mounted the old drive into /media/<myuserID>/<diskUUID>
Become root
sudo su
Install bindfs
apt install bindfs
Stop services
service zoneminder stop
service mysql stop
service apache2 stop
Set current directory to make life easy
cd  /media/<myuserID>/<diskUUID>
Mount the file systems using the appropriate user and group ids.
bindfs -o nonempty -u www-data -g www-data ./var/cache/zoneminder /var/cache/zoneminder
bindfs -o nonempty -u mysql -g mysql ./var/lib/mysql  /var/lib/mysql
Now start the services
service start mysql
service start apache2
service start zoneminder
If you reboot the system you will be back fully on the new zoneminder and all that old data will be unmounted.
