zmtrigger.pl doesn't seem to do anything
I have Axis cameras and want to use their motion detection. I turned on OPT_TRIGGERS and rebooted just to be sure. ps aux shows that zmtrigger.pl is running. netstat shows perl is listening on 6802. If I connect via telnet to 6802 (via localhost) it seems to connect. I entered Purchasing|on+5|1|test|test|test and nothing was recorded. Purchasing is the name of the camera in question. Is there any kind of debugging I can turn on for this script? It doesn't seem to do anything useful at all.
- knight-of-ni
Re: zmtrigger.pl doesn't seem to do anything
Turn on debugging from the Options -> Logging menu.
In ZoneMinder, what function do you have the camera in question set to?
You enter the monitor ID, not its name. If purchasing is monitor number 5 you put 5. Some of the later fields are optional, no need to put 'test' for them. Read the zmtrigger perl script. It is in /usr/bin in Devuan. You must also be in one of modect, mocord, or nodect modes. See http://wiki.zoneminder.com/ZMTrigger
Yes. See http://wiki.zoneminder.com/ZMTrigger
I have it running in nodect mode at the moment. Where do I get the id for each camera then?
- knight-of-ni
From the web console, hover over the monitor in question then look at the url that appears at the bottom of your browser.
The trailing part of the url will have "&mid=xx". xx is the id.
knnniggett thanks, that got me going. I had messed around with cameras a bit and deleted them, so my first id is 9. There is absolutely no mention of id being different than name, or where to get the id, in the documentation. They all just use an example of 1 with no explanation for it.
- knight-of-ni
The documentation does say id or name can be used. However, I've never tried to use the monitor name myself, only the id.
I think the documentation is wrong in this case because I don't see any references to the monitor name in the perl, only the id.
