[SOLVED]1.30.4: Cron doesn't change state (no error)
effe
Post by effe »
AS subject.
Ubuntu 16.04, zmpkg.pl is on /usr/bin/.
From terminal I can change the state with on issue at all with
sudo usr/bin/zmpkg.pl Closed
But I can't with Cron.
After reading the FAQ I added with crontab -e the fellowing lines:
01 7 * * 1-6 root /usr/bin/zmpkg.pl Open
01 22 * * 1-5 root /usr/bin/zmpkg.pl Closed
31 15 * * 6 root /usr/bin/zmpkg.pl Closed
I tried with my user, with www-data and without user and I have no path error but just an output error with another pid in syslog:
effe@DivinaCameras:~$ tail -f /var/log/syslog | grep CRON
Sep  8 11:11:01 DivinaCameras CRON[3547]: (effe) CMD (/usr/bin/zmpkg.pl Closed)
Sep  8 11:11:01 DivinaCameras CRON[3546]: (CRON) info (No MTA installed, discarding output)
Sep  8 11:13:01 DivinaCameras CRON[3587]: (effe) CMD (www-data /usr/bin/zmpkg.pl Closed)
Sep  8 11:13:01 DivinaCameras CRON[3586]: (CRON) info (No MTA installed, discarding output)
Sep  8 11:15:01 DivinaCameras CRON[3636]: (effe) CMD (root /usr/bin/zmpkg.pl Closed)
Sep  8 11:15:01 DivinaCameras CRON[3635]: (CRON) info (No MTA installed, discarding output)
Sep  8 11:34:01 DivinaCameras CRON[3928]: (effe) CMD (effe /usr/bin/zmpkg.pl Closed)
Sep  8 11:34:01 DivinaCameras CRON[3927]: (CRON) info (No MTA installed, discarding output)
Where I'm wrong?
Thanks,
F.
mikb
Re: 1.30.4: Cron doesn't change state (no error)
Post by mikb »
Doesn't look like an error at all :- "info ..." is an informational message. It's saying (I think) that cron tried to email the result of executing the command, and failed, because you don't have an MTA installed.
The output of commands in cron are usually mailed to the user that appears to be running the command.
Also: "Another PID" is also not a problem: an instance of "cron" has started, and the next process started was your job to change state. So the next PID along.
More importantly, does it actually change state, despite these informational warnings?
effe
Post by effe »
Nope. I can change via terminal with or without a full path, but doesn't change with Cron.
Until we can see the output, we are just guessing what the problem might be.
Fix the missing the MTA part
https://askubuntu.com/questions/222512/ ... the-syslog
Then check root's local email and post the output
If i remember you should use www-data not root.
I used Webmin to set up a cron job to change state of Zoneminder. Worked quite well and I did not have to guess at the command line settings!
effe
Post by effe »
EDIT: Soved configuring crontab as root (with sudo -i) without specify user at all.
Don't ask me why...
knnniggett wrote: Sat Sep 09, 2017 1:05 pm Then check root's local email and post the output
for every mail It shows
/bin/sh: root: not found
Same thing with my user and with www-data
Here's a complete email sent:
From effe@DivinaCameras  Mon Sep 11 17:17:01 2017
Return-Path: <effe@DivinaCameras>
X-Original-To: effe
Delivered-To: effe@DivinaCameras
Received: by DivinaCameras (Postfix, from userid 1000)
        id 5A37B46009E; Mon, 11 Sep 2017 17:17:01 -0300 (BRT)
Subject: Cron <effe@DivinaCameras> root /usr/bin/zmpkg.pl Closed
MIME-Version: 1.0
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/home/effe>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=effe>
Message-Id: <20170911201701.5A37B46009E@DivinaCameras>
Date: Mon, 11 Sep 2017 17:17:01 -0300 (BRT)
/bin/sh: 1: root: not found
I've tested on both user and root crontab. In the second case I have no mail output at all for root.
bbunge wrote: Sat Sep 09, 2017 2:06 pm If i remember you should use www-data not root.
tested with user, root, or www-data with no luck.
I'll have a look on it. But why install more package for something that should be working out of the box?
