question about source build error
I wanted to work with the latest from the edge version so attempted to compile but the build stops at 84%
[ 80%] Building CXX object src/CMakeFiles/zm.dir/zm_utils.cpp.o
[ 82%] Building CXX object src/CMakeFiles/zm.dir/zm_video.cpp.o
[ 84%] Building CXX object src/CMakeFiles/zm.dir/zm_videostore.cpp.o
/root/my-applications/zoneminder-master/src/zm_videostore.cpp: In member function ‘bool VideoStore::setup_resampler()’:
/root/my-applications/zoneminder-master/src/zm_videostore.cpp:418:25: error: ‘AVCodecContext’ has no member named ‘refcounted_frames’
   audio_output_context->refcounted_frames = 1;
/root/my-applications/zoneminder-master/src/zm_videostore.cpp: In member function ‘void VideoStore::dumpPacket(AVPacket*)’:
/root/my-applications/zoneminder-master/src/zm_videostore.cpp:593:7: warning: format ‘%lld’ expects argument of type ‘long long int’, but argument 11 has type ‘int’ [-Wformat=]
make[2]: *** [src/CMakeFiles/zm.dir/zm_videostore.cpp.o] Error 1
make[1]: *** [src/CMakeFiles/zm.dir/all] Error 2
make: *** [all] Error
not a critical problem but interested finding out why. It is the first version in awhile not to compile and build successfully.
thanks for any pointers!
Re: question about source build error
The first thing we need to know is how are you trying to build zoneminder? Are you using cmake then make install, or are you trying to build a package using the do_debian script provided by us? The latter is the better way to go. If the former, then it is always good see what cmake -D flags you set when you called cmake.
Moving on to the error, ZoneMinder failed to build against the ffmpeg installed on your system so the questions one must ask are:
- what version of ffmpeg is installed on your system?
- are the ffmpeg development headers installed on your system?
- once we've established that the development headers are installed then we need to know where on your filesystem the headers have been installed to
knnniggett wrote: Fri Jun 09, 2017 2:17 pm - are the ffmpeg development headers installed on your system?
Thanks for the insight. I am using
cmake -C zm_conf.cmake -DZM_CGIDIR=/usr/lib/zoneminder/cgi-bin .
after running
 ./cmakecacheimport.sh /etc/zm/zm.conf
I thought it had something to do with ffmpeg. I am using a static build of ffmpeg version 3.2.2-static. I do not have the development headers installed I believe. my OS is Puppy Linux Tahr 6.0.6 running ZM 1.30.4 with a Hiawatha web server.
I built FFMPEG 3.2.2 from scratch which compiled successfully. I now went past the last error and encounter this now.
Scanning dependencies of target zma
[ 88%] Building CXX object src/CMakeFiles/zma.dir/zma.cpp.o
Linking CXX executable zma
/usr/local/lib/libavutil.a(mathematics.o): In function `av_rescale_delta':
/root/my-applications/ffmpeg-3.3.2/libavutil/mathematics.c:168: multiple definition of `av_rescale_delta'
libzm.a(zm_ffmpeg.cpp.o):zm_ffmpeg.cpp:(.text+0x84c0): first defined here
/usr/bin/ld: /usr/local/lib/libavcodec.a(cuvid.o): undefined reference to symbol 'dlopen@@GLIBC_2.1'
/lib/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[2]: *** [src/zma] Error 1
make[1]: *** [src/CMakeFiles/zma.dir/all] Error 2
make: *** [all] Error 2
any hints?
Any help here or what? Come on and think outside of the box your in...why did it build successfully for me since v 1.26.5 and now it doesn't? what has changed with FFMPEG??? Any thing at all in a form of advice from the masters at the helm?
The is a lot of work being done. Update and try again.
Thanks for the hard work! I will update from the master branch and keep trying to get a successful build again.
I updated to the latest with a git pull then attempted to compile. The build went to 84% and these appeared and halted the compiling.
/root/ftpd/zoneminder-master/src/zm_videostore.cpp: In member function ‘bool VideoStore::setup_resampler()’:
/root/ftpd/zoneminder-master/src/zm_videostore.cpp:436:25: error: ‘AVCodecContext’ has no member named ‘refcounted_frames’
/root/ftpd/zoneminder-master/src/zm_videostore.cpp: In member function ‘void VideoStore::dumpPacket(AVPacket*)’:
/root/ftpd/zoneminder-master/src/zm_videostore.cpp:611:7: warning: format ‘%lld’ expects argument of type ‘long long int’, but argument 11 has type ‘int’ [-Wformat=]
I will keep updating and check if ZM will build.
pulled the latest code from the master branch...tried to build to no avail. Still stops at 84% completion.
I havn't done any testing with ffmpeg 3.3.2 so I will get around to that. Will post here when done.
Today pulled the latest code from the master branch. The build went to 88% and stopped BUT on a different error than before.
root#
sebzmcctv
Post by sebzmcctv »
Dear,
I need Your help, I install zoneminder 1.30.2 from source, every thing
working well, i install 12 cameras on motion detect, 3 cameras working
perfect and rest of all not generating alerts if I opened live feed or open
the montage view and log generating INF ZMS - got signal 15 (exited)
but if I will not opened any live feed alerts generating properly ....
Advance thanks for your kind help.
just for sake of information, I was able to successfully build zoneminder 1.31.1 from source using the code from github zoneminder master branch. Using a Puppy Linux Xenial 7.0.6 operating system that I built using the woof-ce scripts. The compilation worked smoothly and installed on top of a zoneminder 1.29.0 setup. After updating the db and setting the permissions and setting up a zm_custom.conf for the path for the /cgi-bin..... ZM started right up and the log is green.
