I am trying to use a system with 2gig of RAM to record (in raw mp4, no conversion, no motion detection) from 5 cameras(3MP @5fps). It works fine for 1 camera, but when I add another one, the memory is not enough as it seems to be using about half a gig per cam.
Is there a way to limit the RAM usage per camera (e.g. to 100 meg)? I just want to capture the entire raw stream without any modifications.
thanks
Minimize RAM usage?
Re: Minimize RAM usage?
you have to reduce fps, resolution and buffer size.
2GB is too low.
2GB is too low.
I don't understand why ZM needs so much RAM just to dump raw stream to the local storage?????
500 meg of ram would hold 4 minutes of 1080p @5fps video ...
Edit your buffer settings. You are probably telling it to allocate 50 buffer frames, when you probably can get by with less than 5.
you have to consider os overhead in the calculations.
With 2 gig RAM tmpfs uses 1 gig with the other 1 for the os and MySQL. Hi res cameras will use up the tmpfs real quick!
