Any assistance would be appreciated.
Application Error
ClassNotFoundException
com.charliemouse.cabozola.Viewer
I am using IE and unable to view the stream or montage.
I have downloaded the .jar file and placed it in /usr/share/zoneminder.
Did I put it in the correct location?
OPT_CAMBOZOLA = checked.
PATH_CAMBOZOLA = cambozola.jar
Any hints at what else I need to check?
Thank you.
v1.30.2
Ubuntu
Using IE an unable to view the stream or montage.
- zm-log.zip
- (118.04 KiB) Downloaded 82 times
Re: Using IE an unable to view the stream or montage.
it should probably go in /usr/share/zoneminder/www
Thank you iconnor. It worked!
I appreciate all of the work you have done.
