[SOLVED] GPG keys not correct for this package: x265-libs-1.9-3.el7.x86_64
B F
Post by B F » Fri Mar 17, 2017 12:24 pm
When time permits I'll have a proper look at this problem but in the meantime just throwing it out to the community in case anyone has an idea:
Downloading packages:
warning: /var/cache/yum/x86_64/7/zmrepo/packages/x265-libs-1.9-3.el7.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID f5cf6c1e: NOKEY
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7-zmrepo
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-zmrepo
The GPG keys listed for the "Zoneminder and its dependencies for Enterprise Linux 7 - x86_64" repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.
 Failing package is: x265-libs-1.9-3.el7.x86_64
 GPG Keys are configured as: file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7-zmrepo, file:///etc/pki/rpm-gpg/RPM-GPG-KEY-zmrepo
Both /etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7-zmrepo and /etc/pki/rpm-gpg/RPM-GPG-KEY-zmrepo have entries in them.
Re: GPG keys not correct for this package: x265-libs-1.9-3.el7.x86_64
Post by knight-of-ni » Fri Mar 17, 2017 5:14 pm
Please read the sticky at the top of this forum to resolve this issue.
B F
Post by B F » Fri Mar 17, 2017 5:39 pm
Thank you knnniggett that indeed resolved the issue.
Re: [SOLVED] GPG keys not correct for this package: x265-libs-1.9-3.el7.x86_64
Post by knight-of-ni » Fri Mar 17, 2017 5:52 pm
Hey, no problem.
I'm just glad RPMFusion finally started hosting packages for el7. That sure was a long wait.
Users browsing this forum: No registered users and 10 guests
