PTZ issue Trendnet cam : '500 status read failed
Wil
Post by Wil »
I've got two days trying to find how make a my ptz TV-IP420P move with ZM.
I'm using Zm 1.30 on Ubuntu 16.04.1 LTS
I've got a stream and everything works fine with a Ffmpeg source exept moving.
I've tried every controller proposed in /usr/share/perl15/Zoneminder/Control
endind with different kind of errors.
I'm now trying hard with the AirLink SkyIPCam protocol (said to be Trendnet cam friendly), I changed the source type from remote to ffmpeg and the paths.
I still got this message : zmcontrol 3427 ERR Error check failed: '500 Status read failed: Connection reset by peer'.
I tried to chmod + r the control file, nothing changed.
Is anybody got a Trendnet cam ptz mooving on ZM ?
Re: PTZ issue Trendnet cam : '500 status read failed
I've been told the new Hikvision script works with TrendNet. I don't own either brand so I can't verify myself.
https://github.com/ZoneMinder/ZoneMinder/pull/1674
Since is it not yet part of zoneminder, you will have to add the control script and bits of sql manually to your system.
Wil
Post by Wil »
Thank you very much !!
It's working almost perfectly now !
I used the script you told me about, (HikVision)
but I still had the " 3188 FAT 500 Status read failed: Connection reset by peer" error message.
The problem was in the Control Device (Tab Control) I solved it by removing le port, I settled it this way :
user:pwd@IP
thanks a lot.
