So this is my last try before I rollback to ubuntu 14. I'll paste the logs FAT erros here to see if you guys can help me. Sorry for my English, it's not my native languague!
I installed Zoneminder following the wiki.
Date/Time Component Server PID Level Message File Line
2016-09-14 15:54:18.141170 zmc_dvideo0 2882 INF Monitor-1: 2161000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-14 15:54:53.059130 zmupdate 2861 INF Checking for updates zmupdate.pl
2016-09-14 15:54:54.919060 zmupdate 2861 INF Got version: '1.30.0' zmupdate.pl
2016-09-14 15:54:55.094430 zmdc 2751 ERR 'zmupdate.pl -c' exited abnormally, exit status 9 zmdc.pl
2016-09-14 15:54:55.132030 zmdc 2751 INF Starting pending process, zmupdate.pl -c zmdc.pl
2016-09-14 15:54:55.189290 zmdc 2751 INF 'zmupdate.pl -c' starting at 16/09/14 15:54:55, pid = 10595 zmdc.pl
2016-09-14 15:54:55.189340 zmdc 10595 INF 'zmupdate.pl -c' started at 16/09/14 15:54:55 zmdc.pl
2016-09-14 15:54:55.384810 zmupdate 10595 INF Checking for updates zmupdate.pl
2016-09-14 15:54:56.500680 zmupdate 10595 INF Got version: '1.30.0' zmupdate.pl
2016-09-14 15:54:58.105858 zmc_dvideo0 2882 INF Monitor-1: 2162000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-15 13:54:28.452255 zmc_dvideo0 2882 INF Monitor-1: 4143000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-15 13:55:08.417041 zmc_dvideo0 2882 INF Monitor-1: 4144000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 14:08:49.611040 zmpkg 25487 INF Sanity checking States table... zmpkg.pl
2016-09-20 14:08:49.658900 zmpkg 25487 INF Command: start zmpkg.pl
2016-09-20 14:08:50.158120 zmsystemctl 25494 INF Redirecting command through systemctl zmsystemctl.pl
2016-09-20 14:08:50.368690 zmpkg 25505 INF Sanity checking States table... zmpkg.pl
2016-09-20 14:08:50.412460 zmpkg 25505 INF Command: start zmpkg.pl
2016-09-20 14:08:50.795470 zmdc 25523 INF Server starting at 16/09/20 14:08:50 zmdc.pl
2016-09-20 14:08:53.804390 zmpkg 25505 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-09-20 14:08:53.998200 zmdc 25523 INF 'zmc -d /dev/video0' starting at 16/09/20 14:08:53, pid = 25550 zmdc.pl
2016-09-20 14:08:53.998980 zmdc 25550 INF 'zmc -d /dev/video0' started at 16/09/20 14:08:53 zmdc.pl
2016-09-20 14:08:54.117430 zmc_dvideo0 25550 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-20 14:08:54.168220 zmdc 25523 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2016-09-20 14:08:54.204720 zmdc 25523 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2016-09-20 14:08:54.242750 zmdc 25523 INF 'zmc -d /dev/video0' starting at 16/09/20 14:08:54, pid = 25556 zmdc.pl
2016-09-20 14:08:54.243240 zmdc 25556 INF 'zmc -d /dev/video0' started at 16/09/20 14:08:54 zmdc.pl
2016-09-20 14:08:54.283170 zmdc 25557 INF 'zmfilter.pl' started at 16/09/20 14:08:54 zmdc.pl
2016-09-20 14:08:54.283180 zmdc 25523 INF 'zmfilter.pl' starting at 16/09/20 14:08:54, pid = 25557 zmdc.pl
2016-09-20 14:08:54.355706 zmc_dvideo0 25556 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-20 14:08:54.424127 zmc_dvideo0 25556 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-20 14:08:54.517760 zmdc 25523 INF 'zmaudit.pl -c' starting at 16/09/20 14:08:54, pid = 25562 zmdc.pl
2016-09-20 14:08:54.517770 zmdc 25562 INF 'zmaudit.pl -c' started at 16/09/20 14:08:54 zmdc.pl
2016-09-20 14:08:54.592550 zmfilter 25557 INF Scanning for events zmfilter.pl
2016-09-20 14:08:54.750890 zmdc 25570 INF 'zmwatch.pl' started at 16/09/20 14:08:54 zmdc.pl
2016-09-20 14:08:54.750910 zmdc 25523 INF 'zmwatch.pl' starting at 16/09/20 14:08:54, pid = 25570 zmdc.pl
2016-09-20 14:08:54.973160 zmwatch 25570 INF Watchdog starting zmwatch.pl
2016-09-20 14:08:54.998690 zmdc 25576 INF 'zmupdate.pl -c' started at 16/09/20 14:08:54 zmdc.pl
2016-09-20 14:08:54.998710 zmdc 25523 INF 'zmupdate.pl -c' starting at 16/09/20 14:08:54, pid = 25576 zmdc.pl
2016-09-20 14:08:55.016580 zmwatch 25570 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-09-20 14:08:55.212450 zmdc 25523 INF 'zmtelemetry.pl' starting at 16/09/20 14:08:55, pid = 25582 zmdc.pl
2016-09-20 14:08:55.214120 zmdc 25582 INF 'zmtelemetry.pl' started at 16/09/20 14:08:55 zmdc.pl
2016-09-20 14:08:55.221910 zmupdate 25576 INF Checking for updates zmupdate.pl
2016-09-20 14:08:56.418230 zmupdate 25576 INF Got version: '1.30.0' zmupdate.pl
2016-09-20 14:08:57.905170 web_js 25478 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()
2016-09-20 14:08:59.278769 web_php 25478 ERR socket_bind( /var/run/zm/zms-291445w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-09-20 14:08:59.338714 web_js 25478 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-291445w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-09-20 14:09:01.176743 web_php 25477 ERR socket_sendto( /var/run/zm/zms-291445s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-09-20 14:09:01.592053 web_php 25478 ERR socket_sendto( /var/run/zm/zms-291445s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-09-20 14:09:10.660780 zmdc 25523 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-09-20 14:09:10.843180 zmdc 25523 INF 'zmc -d /dev/video0' sending stop to pid 25556 at 16/09/20 14:09:10 zmdc.pl
2016-09-20 14:09:10.883155 zmc_dvideo0 25556 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-20 14:09:10.955210 zmdc 25523 INF 'zmc -d /dev/video0' exited normally zmdc.pl
2016-09-20 14:09:11.143710 zmdc 25656 INF 'zmc -d /dev/video0' started at 16/09/20 14:09:11 zmdc.pl
2016-09-20 14:09:11.143710 zmdc 25523 INF 'zmc -d /dev/video0' starting at 16/09/20 14:09:11, pid = 25656 zmdc.pl
2016-09-20 14:09:11.216754 zmc_dvideo0 25656 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-20 14:09:11.281414 zmc_dvideo0 25656 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-20 14:09:11.334364 zmc_dvideo0 25656 FAT Failed to set camera source 4: Invalid argument zm_local_camera.cpp 885
2016-09-20 14:09:11.367590 zmdc 25523 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-09-20 14:09:11.443100 zmdc 25523 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2016-09-20 14:09:11.585210 zmdc 25523 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2016-09-20 14:09:11.631810 zmdc 25523 INF 'zmc -d /dev/video0' starting at 16/09/20 14:09:11, pid = 25662 zmdc.pl
2016-09-20 14:09:11.631820 zmdc 25662 INF 'zmc -d /dev/video0' started at 16/09/20 14:09:11 zmdc.pl
2016-09-20 14:09:11.746521 zmc_dvideo0 25662 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-20 14:09:11.799161 zmc_dvideo0 25662 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-20 14:09:11.827490 zmc_dvideo0 25662 FAT Failed to set camera source 4: Invalid argument zm_local_camera.cpp 885
2016-09-20 14:09:11.866600 zmdc 25523 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2016-09-20 14:09:14.328051 web_js 25477 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()
2016-09-20 14:09:16.100920 zmdc 25523 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2016-09-20 14:09:16.146680 zmdc 25523 INF 'zmc -d /dev/video0' starting at 16/09/20 14:09:16, pid = 25670 zmdc.pl
2016-09-20 14:09:16.146750 zmdc 25670 INF 'zmc -d /dev/video0' started at 16/09/20 14:09:16 zmdc.pl
2016-09-20 14:09:16.269943 zmc_dvideo0 25670 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-20 14:09:16.322060 zmc_dvideo0 25670 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-20 14:09:16.359133 zmc_dvideo0 25670 FAT Failed to set camera source 4: Invalid argument zm_local_camera.cpp 885
2016-09-20 14:09:16.405790 zmdc 25523 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2016-09-20 14:09:24.376840 zmdc 25523 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-09-20 14:09:24.569180 zmdc 25523 INF Command 'zmc -d /dev/video0' removed from pending list at 16/09/20 14:09:24 zmdc.pl
2016-09-20 14:09:24.751530 zmdc 25683 INF 'zmc -d /dev/video0' started at 16/09/20 14:09:24 zmdc.pl
2016-09-20 14:09:24.751700 zmdc 25523 INF 'zmc -d /dev/video0' starting at 16/09/20 14:09:24, pid = 25683 zmdc.pl
2016-09-20 14:09:24.828942 zmc_dvideo0 25683 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-20 14:09:24.870665 zmc_dvideo0 25683 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-20 14:09:24.961800 zmdc 25523 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-09-20 14:09:27.506298 web_js 23975 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()
2016-09-20 14:10:04.970436 zmc_dvideo0 25683 INF Monitor-1: 1000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 14:10:44.971327 zmc_dvideo0 25683 INF Monitor-1: 2000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 15:23:25.068643 zmc_dvideo0 25683 INF Monitor-1: 111000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 15:23:54.798570 zmaudit 25562 INF Deleted 159 log table entries by time zmaudit.pl
2016-09-20 15:53:25.110523 zmc_dvideo0 25683 INF Monitor-1: 156000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 15:53:54.883850 zmaudit 25562 INF Deleted 56 log table entries by time zmaudit.pl
2016-09-20 15:54:05.111457 zmc_dvideo0 25683 INF Monitor-1: 157000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 15:54:45.112423 zmc_dvideo0 25683 INF Monitor-1: 158000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 16:23:25.152624 zmc_dvideo0 25683 INF Monitor-1: 201000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 16:23:55.082650 zmaudit 25562 INF Deleted 69 log table entries by time zmaudit.pl
2016-09-20 16:24:05.153631 zmc_dvideo0 25683 INF Monitor-1: 202000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 16:24:45.154519 zmc_dvideo0 25683 INF Monitor-1: 203000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 16:53:25.197037 zmc_dvideo0 25683 INF Monitor-1: 246000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 16:53:55.187110 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 16:54:05.197980 zmc_dvideo0 25683 INF Monitor-1: 247000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 16:54:45.198942 zmc_dvideo0 25683 INF Monitor-1: 248000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 17:23:25.239404 zmc_dvideo0 25683 INF Monitor-1: 291000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 17:23:55.302970 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 17:24:05.240347 zmc_dvideo0 25683 INF Monitor-1: 292000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 17:24:45.241288 zmc_dvideo0 25683 INF Monitor-1: 293000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 17:53:25.282560 zmc_dvideo0 25683 INF Monitor-1: 336000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 17:53:55.429000 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 17:54:05.283526 zmc_dvideo0 25683 INF Monitor-1: 337000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 17:54:45.284505 zmc_dvideo0 25683 INF Monitor-1: 338000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 18:23:25.323212 zmc_dvideo0 25683 INF Monitor-1: 381000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 18:23:55.529960 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 18:24:05.324061 zmc_dvideo0 25683 INF Monitor-1: 382000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 18:53:25.352743 zmc_dvideo0 25683 INF Monitor-1: 426000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 18:53:55.689880 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 18:54:05.353457 zmc_dvideo0 25683 INF Monitor-1: 427000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 18:54:45.354159 zmc_dvideo0 25683 INF Monitor-1: 428000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 19:23:25.385292 zmc_dvideo0 25683 INF Monitor-1: 471000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 19:23:55.802000 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 19:24:05.386023 zmc_dvideo0 25683 INF Monitor-1: 472000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 19:24:45.386753 zmc_dvideo0 25683 INF Monitor-1: 473000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 19:53:25.418937 zmc_dvideo0 25683 INF Monitor-1: 516000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 19:53:55.889780 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 19:54:05.419691 zmc_dvideo0 25683 INF Monitor-1: 517000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 20:23:25.452745 zmc_dvideo0 25683 INF Monitor-1: 561000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 20:23:55.990550 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 20:24:05.453436 zmc_dvideo0 25683 INF Monitor-1: 562000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 20:53:25.484104 zmc_dvideo0 25683 INF Monitor-1: 606000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 20:53:56.128110 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 20:54:05.484824 zmc_dvideo0 25683 INF Monitor-1: 607000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 21:23:25.516522 zmc_dvideo0 25683 INF Monitor-1: 651000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 21:23:56.319350 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 21:24:05.517232 zmc_dvideo0 25683 INF Monitor-1: 652000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 21:24:45.517944 zmc_dvideo0 25683 INF Monitor-1: 653000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 21:53:25.548541 zmc_dvideo0 25683 INF Monitor-1: 696000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 21:53:56.423160 zmaudit 25562 INF Deleted 46 log table entries by time zmaudit.pl
2016-09-20 21:54:05.549249 zmc_dvideo0 25683 INF Monitor-1: 697000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 21:54:45.549967 zmc_dvideo0 25683 INF Monitor-1: 698000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 22:23:25.580662 zmc_dvideo0 25683 INF Monitor-1: 741000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 22:23:56.519330 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 22:24:05.581365 zmc_dvideo0 25683 INF Monitor-1: 742000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 22:24:45.582060 zmc_dvideo0 25683 INF Monitor-1: 743000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 22:53:25.610460 zmc_dvideo0 25683 INF Monitor-1: 786000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 22:53:56.656050 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 22:54:05.611134 zmc_dvideo0 25683 INF Monitor-1: 787000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 22:54:45.611788 zmc_dvideo0 25683 INF Monitor-1: 788000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 23:23:25.640499 zmc_dvideo0 25683 INF Monitor-1: 831000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 23:23:56.770260 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 23:24:05.641175 zmc_dvideo0 25683 INF Monitor-1: 832000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 23:24:45.641850 zmc_dvideo0 25683 INF Monitor-1: 833000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 23:53:25.670447 zmc_dvideo0 25683 INF Monitor-1: 876000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 23:53:56.965590 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-20 23:54:05.671109 zmc_dvideo0 25683 INF Monitor-1: 877000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-20 23:54:45.671778 zmc_dvideo0 25683 INF Monitor-1: 878000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 00:23:25.701229 zmc_dvideo0 25683 INF Monitor-1: 921000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 00:23:57.059150 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 00:24:05.701992 zmc_dvideo0 25683 INF Monitor-1: 922000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 00:24:45.702732 zmc_dvideo0 25683 INF Monitor-1: 923000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 00:53:25.734418 zmc_dvideo0 25683 INF Monitor-1: 966000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 00:53:57.152350 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 00:54:05.735157 zmc_dvideo0 25683 INF Monitor-1: 967000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 00:54:45.735892 zmc_dvideo0 25683 INF Monitor-1: 968000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 01:23:25.767554 zmc_dvideo0 25683 INF Monitor-1: 1011000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 01:23:57.267290 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 01:24:05.768269 zmc_dvideo0 25683 INF Monitor-1: 1012000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 01:24:45.768986 zmc_dvideo0 25683 INF Monitor-1: 1013000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 01:53:25.799667 zmc_dvideo0 25683 INF Monitor-1: 1056000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 01:53:57.373630 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 01:54:05.800388 zmc_dvideo0 25683 INF Monitor-1: 1057000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 02:23:25.831403 zmc_dvideo0 25683 INF Monitor-1: 1101000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 02:23:57.570700 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 02:24:05.832096 zmc_dvideo0 25683 INF Monitor-1: 1102000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 02:24:45.832809 zmc_dvideo0 25683 INF Monitor-1: 1103000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 02:52:45.862932 zmc_dvideo0 25683 INF Monitor-1: 1145000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 02:53:25.863666 zmc_dvideo0 25683 INF Monitor-1: 1146000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 02:53:57.673610 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 02:54:05.864394 zmc_dvideo0 25683 INF Monitor-1: 1147000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2[...]
2016-09-21 03:23:25.896550 zmc_dvideo0 25683 INF Monitor-1: 1191000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 03:23:57.806970 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 03:24:05.897291 zmc_dvideo0 25683 INF Monitor-1: 1192000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 03:53:25.929054 zmc_dvideo0 25683 INF Monitor-1: 1236000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 03:53:57.899820 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 03:54:05.929774 zmc_dvideo0 25683 INF Monitor-1: 1237000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 04:23:25.961207 zmc_dvideo0 25683 INF Monitor-1: 1281000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 04:23:58.021760 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 04:24:05.961919 zmc_dvideo0 25683 INF Monitor-1: 1282000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 04:24:45.962630 zmc_dvideo0 25683 INF Monitor-1: 1283000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 04:25:25.963337 zmc_dvideo0 25683 INF Monitor-1: 1284000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 04:53:25.992700 zmc_dvideo0 25683 INF Monitor-1: 1326000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 04:53:58.210000 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 04:54:05.993393 zmc_dvideo0 25683 INF Monitor-1: 1327000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 04:54:45.994091 zmc_dvideo0 25683 INF Monitor-1: 1328000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 05:23:26.024598 zmc_dvideo0 25683 INF Monitor-1: 1371000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 05:23:58.305470 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 05:24:06.025314 zmc_dvideo0 25683 INF Monitor-1: 1372000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 05:53:26.055729 zmc_dvideo0 25683 INF Monitor-1: 1416000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 05:53:58.409010 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 05:54:06.056421 zmc_dvideo0 25683 INF Monitor-1: 1417000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 05:54:46.057119 zmc_dvideo0 25683 INF Monitor-1: 1418000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:52:46.632798 zmc_dvideo0 25683 INF Monitor-1: 2135000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:53:26.633796 zmc_dvideo0 25683 INF Monitor-1: 2136000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:54:00.224910 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 13:54:06.634685 zmc_dvideo0 25683 INF Monitor-1: 2137000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:54:46.635635 zmc_dvideo0 25683 INF Monitor-1: 2138000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:55:26.636573 zmc_dvideo0 25683 INF Monitor-1: 2139000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:56:06.637588 zmc_dvideo0 25683 INF Monitor-1: 2140000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:56:46.638465 zmc_dvideo0 25683 INF Monitor-1: 2141000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:57:26.639404 zmc_dvideo0 25683 INF Monitor-1: 2142000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:58:06.640341 zmc_dvideo0 25683 INF Monitor-1: 2143000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:58:46.641298 zmc_dvideo0 25683 INF Monitor-1: 2144000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 13:59:26.642245 zmc_dvideo0 25683 INF Monitor-1: 2145000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:00:06.643191 zmc_dvideo0 25683 INF Monitor-1: 2146000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:00:46.644136 zmc_dvideo0 25683 INF Monitor-1: 2147000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:01:26.645083 zmc_dvideo0 25683 INF Monitor-1: 2148000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:02:06.646030 zmc_dvideo0 25683 INF Monitor-1: 2149000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:02:46.646977 zmc_dvideo0 25683 INF Monitor-1: 2150000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:03:26.647927 zmc_dvideo0 25683 INF Monitor-1: 2151000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:04:06.648873 zmc_dvideo0 25683 INF Monitor-1: 2152000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:04:46.649813 zmc_dvideo0 25683 INF Monitor-1: 2153000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:05:26.650768 zmc_dvideo0 25683 INF Monitor-1: 2154000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:06:06.651712 zmc_dvideo0 25683 INF Monitor-1: 2155000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:06:46.652666 zmc_dvideo0 25683 INF Monitor-1: 2156000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:07:26.653670 zmc_dvideo0 25683 INF Monitor-1: 2157000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:08:06.654561 zmc_dvideo0 25683 INF Monitor-1: 2158000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:08:46.655510 zmc_dvideo0 25683 INF Monitor-1: 2159000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:08:56.539950 zmupdate 25576 INF Checking for updates zmupdate.pl
2016-09-21 14:08:57.770040 zmupdate 25576 INF Got version: '1.30.0' zmupdate.pl
2016-09-21 14:08:57.824340 zmdc 25523 ERR 'zmupdate.pl -c' exited abnormally, exit status 9 zmdc.pl
2016-09-21 14:08:57.867040 zmdc 25523 INF Starting pending process, zmupdate.pl -c zmdc.pl
2016-09-21 14:08:57.922920 zmdc 1856 INF 'zmupdate.pl -c' started at 16/09/21 14:08:57 zmdc.pl
2016-09-21 14:08:57.923160 zmdc 25523 INF 'zmupdate.pl -c' starting at 16/09/21 14:08:57, pid = 1856 zmdc.pl
2016-09-21 14:08:58.114160 zmupdate 1856 INF Checking for updates zmupdate.pl
2016-09-21 14:09:00.496500 zmupdate 1856 INF Got version: '1.30.0' zmupdate.pl
2016-09-21 14:09:26.656461 zmc_dvideo0 25683 INF Monitor-1: 2160000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:10:06.657418 zmc_dvideo0 25683 INF Monitor-1: 2161000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:10:46.658364 zmc_dvideo0 25683 INF Monitor-1: 2162000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:11:26.659317 zmc_dvideo0 25683 INF Monitor-1: 2163000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:12:06.660262 zmc_dvideo0 25683 INF Monitor-1: 2164000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:12:46.661211 zmc_dvideo0 25683 INF Monitor-1: 2165000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:13:26.662169 zmc_dvideo0 25683 INF Monitor-1: 2166000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:14:06.663129 zmc_dvideo0 25683 INF Monitor-1: 2167000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:14:46.664069 zmc_dvideo0 25683 INF Monitor-1: 2168000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:15:26.665036 zmc_dvideo0 25683 INF Monitor-1: 2169000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:16:06.665981 zmc_dvideo0 25683 INF Monitor-1: 2170000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:16:46.666934 zmc_dvideo0 25683 INF Monitor-1: 2171000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:17:26.667888 zmc_dvideo0 25683 INF Monitor-1: 2172000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:18:06.668838 zmc_dvideo0 25683 INF Monitor-1: 2173000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:18:46.669793 zmc_dvideo0 25683 INF Monitor-1: 2174000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:19:26.670751 zmc_dvideo0 25683 INF Monitor-1: 2175000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:20:06.671716 zmc_dvideo0 25683 INF Monitor-1: 2176000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:20:46.672662 zmc_dvideo0 25683 INF Monitor-1: 2177000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:21:26.673675 zmc_dvideo0 25683 INF Monitor-1: 2178000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:22:06.674578 zmc_dvideo0 25683 INF Monitor-1: 2179000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:22:46.675545 zmc_dvideo0 25683 INF Monitor-1: 2180000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:23:26.676489 zmc_dvideo0 25683 INF Monitor-1: 2181000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:24:00.376210 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 14:24:06.677448 zmc_dvideo0 25683 INF Monitor-1: 2182000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 14:24:46.678400 zmc_dvideo0 25683 INF Monitor-1: 2183000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:53:26.807802 zmc_dvideo0 25683 INF Monitor-1: 2316000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:54:00.754010 zmaudit 25562 INF Deleted 45 log table entries by time zmaudit.pl
2016-09-21 15:54:06.808799 zmc_dvideo0 25683 INF Monitor-1: 2317000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:54:46.809777 zmc_dvideo0 25683 INF Monitor-1: 2318000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:55:26.810759 zmc_dvideo0 25683 INF Monitor-1: 2319000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:56:06.811744 zmc_dvideo0 25683 INF Monitor-1: 2320000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:56:46.812731 zmc_dvideo0 25683 INF Monitor-1: 2321000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:57:26.813771 zmc_dvideo0 25683 INF Monitor-1: 2322000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:58:06.814706 zmc_dvideo0 25683 INF Monitor-1: 2323000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:58:46.815690 zmc_dvideo0 25683 INF Monitor-1: 2324000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 15:59:26.816675 zmc_dvideo0 25683 INF Monitor-1: 2325000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:00:06.817716 zmc_dvideo0 25683 INF Monitor-1: 2326000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:00:46.818644 zmc_dvideo0 25683 INF Monitor-1: 2327000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:01:26.819635 zmc_dvideo0 25683 INF Monitor-1: 2328000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:02:06.820645 zmc_dvideo0 25683 INF Monitor-1: 2329000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:02:46.821713 zmc_dvideo0 25683 INF Monitor-1: 2330000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:03:26.822667 zmc_dvideo0 25683 INF Monitor-1: 2331000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:04:06.823681 zmc_dvideo0 25683 INF Monitor-1: 2332000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:04:46.824800 zmc_dvideo0 25683 INF Monitor-1: 2333000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:05:26.825773 zmc_dvideo0 25683 INF Monitor-1: 2334000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:06:06.826731 zmc_dvideo0 25683 INF Monitor-1: 2335000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:06:46.827624 zmc_dvideo0 25683 INF Monitor-1: 2336000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:07:26.828755 zmc_dvideo0 25683 INF Monitor-1: 2337000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:08:06.829808 zmc_dvideo0 25683 INF Monitor-1: 2338000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:08:46.830814 zmc_dvideo0 25683 INF Monitor-1: 2339000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:09:26.831766 zmc_dvideo0 25683 INF Monitor-1: 2340000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:10:06.832781 zmc_dvideo0 25683 INF Monitor-1: 2341000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:10:46.833779 zmc_dvideo0 25683 INF Monitor-1: 2342000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:11:26.834792 zmc_dvideo0 25683 INF Monitor-1: 2343000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:11:29.757390 web_js 1166 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()
2016-09-21 16:12:06.835782 zmc_dvideo0 25683 INF Monitor-1: 2344000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:12:46.836784 zmc_dvideo0 25683 INF Monitor-1: 2345000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:13:26.837788 zmc_dvideo0 25683 INF Monitor-1: 2346000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:14:06.838789 zmc_dvideo0 25683 INF Monitor-1: 2347000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:14:46.839784 zmc_dvideo0 25683 INF Monitor-1: 2348000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:15:26.840781 zmc_dvideo0 25683 INF Monitor-1: 2349000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:16:06.841779 zmc_dvideo0 25683 INF Monitor-1: 2350000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:16:46.842771 zmc_dvideo0 25683 INF Monitor-1: 2351000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:17:26.843766 zmc_dvideo0 25683 INF Monitor-1: 2352000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:18:06.844768 zmc_dvideo0 25683 INF Monitor-1: 2353000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:18:46.845756 zmc_dvideo0 25683 INF Monitor-1: 2354000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:19:26.846749 zmc_dvideo0 25683 INF Monitor-1: 2355000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:20:06.847745 zmc_dvideo0 25683 INF Monitor-1: 2356000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:20:46.848726 zmc_dvideo0 25683 INF Monitor-1: 2357000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:21:05.513423 web_js 1166 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()
2016-09-21 16:21:26.849802 zmc_dvideo0 25683 INF Monitor-1: 2358000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:22:06.850714 zmc_dvideo0 25683 INF Monitor-1: 2359000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:22:46.851700 zmc_dvideo0 25683 INF Monitor-1: 2360000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:23:26.852686 zmc_dvideo0 25683 INF Monitor-1: 2361000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:23:56.079320 zmpkg 20779 INF Sanity checking States table... zmpkg.pl
2016-09-21 16:23:56.117940 zmpkg 20779 INF Command: restart zmpkg.pl
2016-09-21 16:23:56.377620 zmsystemctl 20785 INF Redirecting command through systemctl zmsystemctl.pl
2016-09-21 16:23:56.573020 zmpkg 20796 INF Sanity checking States table... zmpkg.pl
2016-09-21 16:23:56.618300 zmpkg 20796 INF Command: stop zmpkg.pl
2016-09-21 16:23:57.018800 zmdc 25523 INF 'zmc -d /dev/video0' sending stop to pid 25683 at 16/09/21 16:23:57 zmdc.pl
2016-09-21 16:23:57.058144 zmc_dvideo0 25683 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-21 16:23:57.058260 zmdc 25523 INF 'zmupdate.pl -c' sending stop to pid 1856 at 16/09/21 16:23:57 zmdc.pl
2016-09-21 16:23:57.125300 zmdc 25523 INF 'zmfilter.pl' sending stop to pid 25557 at 16/09/21 16:23:57 zmdc.pl
2016-09-21 16:23:57.158800 zmdc 25523 INF 'zmc -d /dev/video0' exited normally zmdc.pl
2016-09-21 16:23:57.200680 zmdc 25523 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-09-21 16:23:57.234410 zmdc 25523 INF 'zmtelemetry.pl' sending stop to pid 25582 at 16/09/21 16:23:57 zmdc.pl
2016-09-21 16:23:57.277270 zmdc 25523 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-09-21 16:23:57.319300 zmdc 25523 INF 'zmwatch.pl' sending stop to pid 25570 at 16/09/21 16:23:57 zmdc.pl
2016-09-21 16:23:57.361040 zmdc 25523 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-09-21 16:23:57.402980 zmdc 25523 INF 'zmaudit.pl -c' sending stop to pid 25562 at 16/09/21 16:23:57 zmdc.pl
2016-09-21 16:23:57.444750 zmdc 25523 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-09-21 16:23:57.488340 zmdc 25523 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-09-21 16:24:07.741590 zmdc 25523 INF Server shutdown at 16/09/21 16:24:07 zmdc.pl
2016-09-21 16:24:07.987640 zmpkg 20837 INF Sanity checking States table... zmpkg.pl
2016-09-21 16:24:08.033320 zmpkg 20837 INF Command: start zmpkg.pl
2016-09-21 16:24:08.422890 zmdc 20855 INF Server starting at 16/09/21 16:24:08 zmdc.pl
2016-09-21 16:24:11.432500 zmpkg 20837 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-09-21 16:24:11.625190 zmdc 20855 INF 'zmc -d /dev/video0' starting at 16/09/21 16:24:11, pid = 20881 zmdc.pl
2016-09-21 16:24:11.625210 zmdc 20881 INF 'zmc -d /dev/video0' started at 16/09/21 16:24:11 zmdc.pl
2016-09-21 16:24:11.747544 zmc_dvideo0 20881 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-21 16:24:11.795800 zmdc 20855 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2016-09-21 16:24:11.832460 zmdc 20855 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2016-09-21 16:24:11.879100 zmdc 20855 INF 'zmc -d /dev/video0' starting at 16/09/21 16:24:11, pid = 20885 zmdc.pl
2016-09-21 16:24:11.879130 zmdc 20885 INF 'zmc -d /dev/video0' started at 16/09/21 16:24:11 zmdc.pl
2016-09-21 16:24:11.950385 zmc_dvideo0 20885 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-21 16:24:11.963310 zmdc 20855 INF 'zmfilter.pl' starting at 16/09/21 16:24:11, pid = 20886 zmdc.pl
2016-09-21 16:24:11.963330 zmdc 20886 INF 'zmfilter.pl' started at 16/09/21 16:24:11 zmdc.pl
2016-09-21 16:24:12.016708 zmc_dvideo0 20885 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-21 16:24:12.194760 zmdc 20891 INF 'zmaudit.pl -c' started at 16/09/21 16:24:12 zmdc.pl
2016-09-21 16:24:12.194940 zmdc 20855 INF 'zmaudit.pl -c' starting at 16/09/21 16:24:12, pid = 20891 zmdc.pl
2016-09-21 16:24:12.268230 zmfilter 20886 INF Scanning for events zmfilter.pl
2016-09-21 16:24:12.426240 zmdc 20855 INF 'zmwatch.pl' starting at 16/09/21 16:24:12, pid = 20897 zmdc.pl
2016-09-21 16:24:12.428220 zmdc 20897 INF 'zmwatch.pl' started at 16/09/21 16:24:12 zmdc.pl
2016-09-21 16:24:12.644450 zmwatch 20897 INF Watchdog starting zmwatch.pl
2016-09-21 16:24:12.670510 zmdc 20904 INF 'zmupdate.pl -c' started at 16/09/21 16:24:12 zmdc.pl
2016-09-21 16:24:12.670940 zmdc 20855 INF 'zmupdate.pl -c' starting at 16/09/21 16:24:12, pid = 20904 zmdc.pl
2016-09-21 16:24:12.685250 zmwatch 20897 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-09-21 16:24:12.887100 zmdc 20909 INF 'zmtelemetry.pl' started at 16/09/21 16:24:12 zmdc.pl
2016-09-21 16:24:12.887230 zmdc 20855 INF 'zmtelemetry.pl' starting at 16/09/21 16:24:12, pid = 20909 zmdc.pl
2016-09-21 16:24:52.134747 zmc_dvideo0 20885 INF Monitor-1: 1000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:25:32.135704 zmc_dvideo0 20885 INF Monitor-1: 2000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:26:01.551453 web_js 1167 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://2.2.2.5/zm/tools/mootools/mootools-more.js 1
2016-09-21 16:26:02.423713 web_js 1167 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://2.2.2.5/zm/tools/mootools/mootools-more.js 1
2016-09-21 16:26:02.609048 web_js 1167 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://2.2.2.5/zm/tools/mootools/mootools-more.js 1
2016-09-21 16:26:02.752028 web_js 1167 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://2.2.2.5/zm/tools/mootools/mootools-more.js 1
2016-09-21 16:26:02.920894 web_js 1167 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://2.2.2.5/zm/tools/mootools/mootools-more.js 1
2016-09-21 16:26:09.584340 zmpkg 20956 INF Sanity checking States table... zmpkg.pl
2016-09-21 16:26:09.621480 zmpkg 20956 INF Command: stop zmpkg.pl
2016-09-21 16:26:09.990170 zmdc 20855 INF 'zmfilter.pl' sending stop to pid 20886 at 16/09/21 16:26:09 zmdc.pl
2016-09-21 16:26:10.028310 zmdc 20855 INF 'zmupdate.pl -c' sending stop to pid 20904 at 16/09/21 16:26:10 zmdc.pl
2016-09-21 16:26:10.070170 zmdc 20855 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-09-21 16:26:10.103850 zmdc 20855 INF 'zmwatch.pl' sending stop to pid 20897 at 16/09/21 16:26:10 zmdc.pl
2016-09-21 16:26:10.137260 zmdc 20855 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-09-21 16:26:10.171000 zmdc 20855 INF 'zmc -d /dev/video0' sending stop to pid 20885 at 16/09/21 16:26:10 zmdc.pl
2016-09-21 16:26:10.204440 zmdc 20855 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-09-21 16:26:10.246330 zmc_dvideo0 20885 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-21 16:26:10.246430 zmdc 20855 INF 'zmtelemetry.pl' sending stop to pid 20909 at 16/09/21 16:26:10 zmdc.pl
2016-09-21 16:26:10.330030 zmdc 20855 INF 'zmc -d /dev/video0' exited normally zmdc.pl
2016-09-21 16:26:10.371970 zmdc 20855 INF 'zmaudit.pl -c' sending stop to pid 20891 at 16/09/21 16:26:10 zmdc.pl
2016-09-21 16:26:10.413820 zmdc 20855 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-09-21 16:26:10.458840 zmdc 20855 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-09-21 16:26:20.652500 zmdc 20855 INF Server shutdown at 16/09/21 16:26:20 zmdc.pl
2016-09-21 16:26:20.895090 zmpkg 20994 INF Sanity checking States table... zmpkg.pl
2016-09-21 16:26:20.936890 zmpkg 20994 INF Command: start zmpkg.pl
2016-09-21 16:26:21.308480 zmdc 21010 INF Server starting at 16/09/21 16:26:21 zmdc.pl
2016-09-21 16:26:24.317390 zmpkg 20994 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-09-21 16:26:24.508330 zmdc 21010 INF 'zmc -d /dev/video0' starting at 16/09/21 16:26:24, pid = 21036 zmdc.pl
2016-09-21 16:26:24.508340 zmdc 21036 INF 'zmc -d /dev/video0' started at 16/09/21 16:26:24 zmdc.pl
2016-09-21 16:26:24.588100 zmc_dvideo0 21036 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-21 16:26:24.621310 zmdc 21010 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2016-09-21 16:26:24.649830 zmdc 21010 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2016-09-21 16:26:24.696760 zmdc 21010 INF 'zmc -d /dev/video0' starting at 16/09/21 16:26:24, pid = 21039 zmdc.pl
2016-09-21 16:26:24.696770 zmdc 21039 INF 'zmc -d /dev/video0' started at 16/09/21 16:26:24 zmdc.pl
2016-09-21 16:26:24.779267 zmc_dvideo0 21039 INF Selected capture palette: 24-bit BGR 8-8-8 (BGR3) zm_local_camera.cpp 351
2016-09-21 16:26:24.787000 zmdc 21041 INF 'zmfilter.pl' started at 16/09/21 16:26:24 zmdc.pl
2016-09-21 16:26:24.787230 zmdc 21010 INF 'zmfilter.pl' starting at 16/09/21 16:26:24, pid = 21041 zmdc.pl
2016-09-21 16:26:24.843924 zmc_dvideo0 21039 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-21 16:26:25.020200 zmdc 21010 INF 'zmaudit.pl -c' starting at 16/09/21 16:26:25, pid = 21046 zmdc.pl
2016-09-21 16:26:25.020520 zmdc 21046 INF 'zmaudit.pl -c' started at 16/09/21 16:26:25 zmdc.pl
2016-09-21 16:26:25.094060 zmfilter 21041 INF Scanning for events zmfilter.pl
2016-09-21 16:26:25.253310 zmdc 21052 INF 'zmwatch.pl' started at 16/09/21 16:26:25 zmdc.pl
2016-09-21 16:26:25.253480 zmdc 21010 INF 'zmwatch.pl' starting at 16/09/21 16:26:25, pid = 21052 zmdc.pl
2016-09-21 16:26:25.420500 zmwatch 21052 INF Watchdog starting zmwatch.pl
2016-09-21 16:26:25.459810 zmwatch 21052 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-09-21 16:26:25.505780 zmdc 21010 INF 'zmupdate.pl -c' starting at 16/09/21 16:26:25, pid = 21059 zmdc.pl
2016-09-21 16:26:25.506230 zmdc 21059 INF 'zmupdate.pl -c' started at 16/09/21 16:26:25 zmdc.pl
2016-09-21 16:26:25.746880 zmdc 21064 INF 'zmtelemetry.pl' started at 16/09/21 16:26:25 zmdc.pl
2016-09-21 16:26:25.747160 zmdc 21010 INF 'zmtelemetry.pl' starting at 16/09/21 16:26:25, pid = 21064 zmdc.pl
2016-09-21 16:27:04.957816 zmc_dvideo0 21039 INF Monitor-1: 1000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:27:44.958698 zmc_dvideo0 21039 INF Monitor-1: 2000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:28:24.959570 zmc_dvideo0 21039 INF Monitor-1: 3000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:29:04.960442 zmc_dvideo0 21039 INF Monitor-1: 4000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:29:44.961311 zmc_dvideo0 21039 INF Monitor-1: 5000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:30:24.962181 zmc_dvideo0 21039 INF Monitor-1: 6000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:31:04.963046 zmc_dvideo0 21039 INF Monitor-1: 7000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:31:44.963910 zmc_dvideo0 21039 INF Monitor-1: 8000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:32:24.964773 zmc_dvideo0 21039 INF Monitor-1: 9000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:33:04.965690 zmc_dvideo0 21039 INF Monitor-1: 10000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:33:44.966504 zmc_dvideo0 21039 INF Monitor-1: 11000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:34:24.967363 zmc_dvideo0 21039 INF Monitor-1: 12000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:35:04.968223 zmc_dvideo0 21039 INF Monitor-1: 13000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:35:44.969080 zmc_dvideo0 21039 INF Monitor-1: 14000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:36:24.969925 zmc_dvideo0 21039 INF Monitor-1: 15000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:37:04.970787 zmc_dvideo0 21039 INF Monitor-1: 16000 - Capturing at 25.00 fps zm_monitor.cpp 3116
2016-09-21 16:37:44.971664 zmc_dvideo0 21039 INF Monitor-1: 17000 - Capturing at 25.00 fps zm_monitor.cpp 3116
