Cannot write to content dirs
redxiii
Post by redxiii » Sun Jun 21, 2020 9:16 pm
I cloned an old system to a new system and now getting the error when I try to access the console,
Cannot write to content dirs('events','images'). Check that these exist and are owned by the web account user
Yes they do exist and are owned by www-data. All the data is the same as in the last system which was working fine. Just the computer has changed. /var/cache/zoneminder is on a different partition. Any ideas? I searched around but didn't notice anything relevant. Thanks
root@gemma:~# ls -la /var/cache/zoneminder/
total 36
drwxr-xr-x  6 www-data www-data  4096 Jun 20 22:01 .
drwxr-xr-x 10 root     root      4096 Jul  2  2016 ..
drwxr-xr-x  7 www-data www-data  4096 Jun  8  2017 events
drwxr-xr-x  2 www-data www-data  4096 Jun 26  2016 images
drwx------  2 root     root     16384 Feb 16  2017 lost+found
drwxr-xr-x  2 www-data www-data  4096 Nov 11  2017 temp
root@gemma:~# ls -la /usr/share/zoneminder/www
total 60
drwxr-xr-x 13 www-data www-data 4096 Jun 20 21:39 .
drwxr-xr-x  4 www-data www-data 4096 Jun 25  2016 ..
drwxr-xr-x  2 www-data www-data 4096 Jun 25  2016 ajax
drwxr-xr-x  4 www-data www-data 4096 Jun 25  2016 api
drwxr-xr-x  2 www-data www-data 4096 Jun 25  2016 css
drwxr-xr-x  7 www-data www-data 4096 Jun 20 21:39 events
drwxr-xr-x  2 www-data www-data 4096 Jun 25  2016 graphics
drwxr-xr-x  2 www-data www-data 4096 Jun 25  2016 includes
-rw-r--r--  1 www-data www-data 6435 Feb  3  2016 index.php
drwxr-xr-x  2 www-data www-data 4096 Jun 25  2016 js
drwxr-xr-x  2 www-data www-data 4096 Jun 25  2016 lang
drwxr-xr-x  5 www-data www-data 4096 Jun 25  2016 skins
drwxr-xr-x  3 www-data www-data 4096 Jun 25  2016 tools
drwxr-xr-x  2 www-data www-data 4096 Jun 25  2016 views
root@gemma:~# service zoneminder status
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
   Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled)
   Active: active (running) since Sun 2020-06-21 14:11:46 MST; 12min ago
  Process: 23352 ExecStop=/usr/bin/zmpkg.pl stop (code=exited, status=0/SUCCESS)
  Process: 23395 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
 Main PID: 23414 (zmdc.pl)
   CGroup: /system.slice/zoneminder.service
           ├─23414 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
           ├─23446 /usr/bin/zma -m 1
           ├─23479 /usr/bin/zma -m 3
           ├─23498 /usr/bin/zma -m 4
           ├─23523 /usr/bin/zma -m 5
           ├─23526 /usr/bin/perl -wT /usr/bin/zmfilter.pl
           ├─23534 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
           ├─23543 /usr/bin/perl -wT /usr/bin/zmtrigger.pl
           ├─23553 /usr/bin/perl -wT /usr/bin/zmwatch.pl
           ├─23557 /usr/bin/zma -m 2
           ├─23731 /usr/bin/zmc -m 2
           ├─23736 /usr/bin/zmc -m 3
           ├─23741 /usr/bin/zmc -m 4
           ├─23746 /usr/bin/zmc -m 5
           └─23754 /usr/bin/zmc -m 1
Jun 21 14:22:47 gemma zmc[23715]: WAR [Can't connect to remote camera: Connection timed out]
Jun 21 14:22:47 gemma zmc[23715]: ERR [Unable to connect to the remote camera, aborting]
Jun 21 14:22:47 gemma zmc[23715]: ERR [Unable to connect to camera]
Jun 21 14:22:47 gemma zmc[23715]: ERR [Failed to pre-capture monitor 1 -1761374780 (1/1)]
Jun 21 14:22:47 gemma zmdc[23414]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jun 21 14:22:50 gemma zmwatch[23553]: INF [Restarting capture daemon for Carport, shared data not valid]
Jun 21 14:22:51 gemma zmdc[23754]: INF ['zmc -m 1' started at 20/06/21 14:22:51]
Jun 21 14:22:51 gemma zmdc[23414]: INF ['zmc -m 1' starting at 20/06/21 14:22:51, pid = 23754]
Jun 21 14:22:51 gemma undef[23754]: INF [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
Jun 21 14:22:51 gemma zmc[23754]: INF [Starting Capture version 1.29.0]
root@gemma:~#
The errors shown are expected since the machine is at my house and not the site with the cameras. I just need to access the console to make sure everything is OK.
redxiii
Re: Cannot write to content dirs
Post by redxiii » Sun Jun 21, 2020 9:45 pm
I make the change indicated here, https://github.com/ZoneMinder/zoneminde ... 1412/files and now can get into the console at least, but still getting the error over and over,
Strange if you ask me since i just cloned everything over from the old HD, is it because the computer is on my network and not the client's network? We will see
redxiii
Post by redxiii » Wed Jun 24, 2020 12:18 am
It looks good now, all the errors have gone away and ZM is working as expected. Guess changing the network on the computer has adverse effects.
