Analysis FPS not being applied exactly
nirv199
Post by nirv199 »
Hi
It seems most monitors I have set the "Analysis FPS" to be lower than the the actual feed FPS are not the value I set. For instance, all my cameras are set to feed 12 FPS, and I have configured Analysis FPS to be 6 FPS. The analysis FPS (when seeing the log file) is anywhere from 6 to 10 FPS (most being 8 FPS). I even tried lowering to 4 FPS a camera that was always analysing at 10 FPS with no difference to the outcome.
Is there something in particular that needs to happen for the value entered on Analysis FPS to the taken exactly as it is? Anything in special to the frame buffer size in memory?
