Hi, I'm trying to connect with zmNinja to my server where ZoneMinder is running in docker.
When I try to view monitors live or montage I ain't got images. On the server it all works well.
I've gone through a lot of tries and read the documentation and done the checklist you recommended
I tried all different paths in zmNinja configuration following different forum posts and guides... perhaps the issue is with certificate...no luck
I hope you can give me some hint about this problem. thanks
zmNinja streaming problems
- zmNinjaLog.txt
- (19.87 KiB) Downloaded 76 times
