Need testers for ES code (multiple model chaining/ arbitrary frames)
Discussion topics related to mobile applications for ZoneMinder
asker
Post by asker » Wed Dec 30, 2020 9:33 pm
The new version of ES support model chaining as well as inspecting multiple frames in an event.
I am looking for folks to:
1. Update to the new ES
2. Test if current operation works without making any config changes (that is, new code with old functionality)
3. Test new functionality.
Specifically, I want to know if folks update to the new ES and face any errors (without making changes to config)
Steps are here: https://github.com/pliablepixels/zmeven ... -749162186
Would appreciate feedback
Please don't ask me questions via PM. Feel free to post in the forums or Github
Re: Need testers for ES code (multiple model chaining/ arbitrary frames)
Post by Magic919 » Thu Dec 31, 2020 11:59 am
I'm in.
Have pulled and installed latest. No othe changes, just a restart of ZMES.
asker
Post by asker » Thu Dec 31, 2020 1:52 pm
I'm in.
Thanks! I've added the following note to Part I - when you test with no changes:
Specifically, make sure all your objectconfig changes you might have implemented earlier, like monitor specific waits, detection_pattern etc. continue to work with the changed values
Post by Magic919 » Sat Jan 02, 2021 2:36 pm
I haven't seen a single known face since the upgrade. Deleted my old faces.dat, but no help. Trying to retrain threw an error.
Tried it against an old alarm that 'knew' my face and got
01/02/21 14:27:40 zmesdetect_mm9[3746936] FAT zm_detect.py:860 [Unrecoverable error:int() can't convert non-string with explicit base Traceback:Traceback (most recent call last):
  File "/var/lib/zmeventnotification/bin/zm_detect.py", line 857, in <module>
    main_handler()
  File "/var/lib/zmeventnotification/bin/zm_detect.py", line 348, in main_handler
    m = face.Face(logger=g.logger, options=g.config, upsample_times=g.config['face_upsample_times'],
  File "/usr/local/lib/python3.8/dist-packages/pyzm/ml/face.py", line 92, in __init__
    train.FaceTrain(options=self.options).train()
  File "/usr/local/lib/python3.8/dist-packages/pyzm/ml/face_train.py", line 35, in train
    num_jitters = int(self.options.get('face_num_jitters'),0)
TypeError: int() can't convert non-string with explicit base
asker
Post by asker » Sat Jan 02, 2021 4:00 pm
whoops - fixed in 0.3.19 pyzm
Post by Magic919 » Sat Jan 02, 2021 4:09 pm
Ok, just trained faces successfully. Will check on alarms shortly.
Thanks.
Post by Magic919 » Sun Jan 03, 2021 3:33 pm
I've emailed over some debug as I'm still getting the unknown faces, even on old events that showed as known.
Post by Magic919 » Mon Jan 04, 2021 8:02 am
Thanks for the rapid fix, back on track now.
tsp84
Post by tsp84 » Mon Jan 04, 2021 6:59 pm
Upgrading to pyzm 0.3.19 fixes that face detection error?
Post by Magic919 » Mon Jan 04, 2021 7:08 pm
Yes, it did.
warcanoid
Post by warcanoid » Tue Jan 05, 2021 4:32 pm
How to fix this, have same erro with object in docker?
root@16faf02ec93a:/# pip3 install pyzmq 0.3.19
Requirement already satisfied: pyzmq in /usr/local/lib/python3.8/dist-packages (20.0.0)
ERROR: Could not find a version that satisfies the requirement 0.3.19 (from versions: none)
ERROR: No matching distribution found for 0.3.19
2021-01-05 17:31:22	zmesdetect_m5		1231	FAT	Unrecoverable error:'ml_sequence' Traceback:Traceback (most recent call last): File "/var/lib/zmeventnotification/bin/zm_detect.py", line 531, in <module> main_handler() File "/var/lib/zmeventnotification/bin/zm_detect.py", line 295, in main_handler if g.config['ml_sequence'] and g.config['use_sequence'] == 'yes':KeyError: 'ml_sequence'	zm_detect.py	534
Post by Magic919 » Tue Jan 05, 2021 5:06 pm
It’s not pyzmq.
warcanoid
Post by warcanoid » Tue Jan 05, 2021 5:17 pm
added new config for ES in objectconfig.ini:
[ml]
use_sequence = yes
disable_locks= no
stream_sequence = {
'frame_strategy': 'most_models',
'frame_set': 'snapshot,alarm',
'contig_frames_before_error': 5,
'max_attempts': 3,
'sleep_between_attempts': 4,
'resize':800
ml_sequence= {
'general': {
'model_sequence': 'object'
'object': {
'general':{
'pattern':'(car|truck|bicycle|motorbike|bus|person|dog|cat)',
'same_model_sequence_strategy': 'first' # also 'most', 'most_unique's
'sequence': [{
# YoloV4 on GPU if TPU fails (because sequence strategy is 'first')
'object_config':'{{base_data_path}}/models/yolov4/yolov4.cfg',
'object_weights':'{{base_data_path}}/models/yolov4/yolov4.weights',
'object_labels': '{{base_data_path}}/models/yolov4/coco.names',
'object_min_confidence': 0.3,
'object_framework':'opencv',
'object_processor': 'gpu'
Also tried to disable use_sequence: no, but dont work.
Post by Magic919 » Tue Jan 05, 2021 5:38 pm
Did you do the update of pyzm?
warcanoid
Post by warcanoid » Tue Jan 05, 2021 9:42 pm
yes
