I dont use mobil push notifications and i see in the logfile every 5 minutes the following message
ERR [PARENT: Could not parse token file for token counts: ]
How can i disable this message ?
Thanks in advance for your support.
zmeventnotification tokens.txt
Re: zmeventnotification tokens.txt
For now, just do
I've fixed the next version not to update tokens if use_fcm is disabled.
sudo echo {} > /var/lib/zmeventnotification/push/tokens.txt
sudo chown www-data:www-data /var/lib/zmeventnotification/push/tokens.txt
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Thank you for the quick answer
