Page 1 of 1
having issues getting hooks going
Posted: Mon Jun 29, 2020 8:58 pm
by lorenjz
I've been trying to read and exhaust all of the resources I could to track this down. I was successful in getting the notifications for zmninja setup. I'd like to get hooks going and some integration working with my home automation.
I do have encryption setup and working both for browsers and the zmninja. In the setup of that camera, storage tab, the jpeg writer is set to "Frames + Analysis (if available)". I've been trying all of this with one camera to minimize any configuration differences.
When I try this command:
sudo -u www-data /var/lib/zmeventnotification/bin/zm_event_start.sh -e 2026
This is the response displayed on command line:
usage: zm_detect.py [-h] [-c CONFIG] [-e EVENTID] [-p EVENTPATH]
[-m MONITORID] [-v] [-o OUTPUT_PATH] [-f FILE] [-r REASON]
zm_detect.py: error: argument -e/--eventid: expected one argument
Did I misunderstand how the command was supposed to be executed?
Any input or suggestions would be greatly appreciated!
Edit:
I'm running Zoneminder 1.34.15
Zmninja v1.4.007
Re: having issues getting hooks going
Posted: Mon Jun 29, 2020 11:52 pm
by asker
sudo -u www-data /var/lib/zmeventnotification/bin/zm_event_start.sh <eid> <mid>
There is no -e
Posted: Wed Jul 01, 2020 1:55 pm
by lorenjz
Thanks @asker!
It appears as though I have an error somewhere in my objectconfig. When I run zm_event_start.sh manually and then execute: tail -F /var/log/zm/zmesdetect_m*.log the log shows this:
07/01/20 08:49:14 zmesdetect_m17[7706] ERR utils.py:347 [Error parsing config:/etc/zm/objectconfig.ini]
07/01/20 08:49:14 zmesdetect_m17[7706] ERR utils.py:348 [Error was:Python type HTTPError cannot be converted]
Is there a log that would be more descriptive as to where the objectconfig.ini is causing the error?
Thanks again!
Loren
Posted: Wed Jul 01, 2020 2:26 pm
by lorenjz
Nevermind... I found that this: https://github.com/pliablepixels/zmeven ... issues/156 was the issue
Posted: Thu Jul 09, 2020 7:08 pm
by lorenjz
My vm running zoneminder died the other day. I'm tryiing to get everything back up and running. When I execute:
I receive an error:
Traceback (most recent call last):
File "/var/lib/zmeventnotification/bin/zm_detect.py", line 15, in <module>
import imutils
ModuleNotFoundError: No module named 'imutils'
A I did do a couple of searches for that error and came up empty...
Any help would be greatly appreciated!
Posted: Thu Jul 09, 2020 9:09 pm
by asker
That means you are missing "imutils" as a dependent package for detection to work. Not sure how you installed it, but I'd suggest reinstalling using the official install instructions of using install.sh to make sure all dependencies are pulled. make sure you monitor the output of the installation.
Posted: Thu Jul 09, 2020 10:28 pm
by lorenjz
Yup, I did rerun sudo -H ./install.sh. I watched and noticed that during the script was running that one of the console lines printed:
Requirement already satisfied: imutils in /root/.local/lib/python3.8/site-packages (from zmes-hooks==5.15.6) (0.5.3)
I uninstalled imutils and then redownloaded the install folder from github. Then reran the script, restarted, and then tried again with the same result.
Thoughts?
Posted: Fri Jul 10, 2020 1:48 am
by asker
Is this path accessible by www-data? If not then when you run as www-data it won’t find libs.
Posted: Fri Jul 10, 2020 5:00 pm
by lorenjz
@asker thanks for your help with all of this! I was able to get the imutils permissions thing sorted I think. Then I had this pop up
File "/var/lib/zmeventnotification/bin/zm_detect.py", line 402, in <module>
b, l, c = m.detect(image)
File "/usr/local/lib/python3.8/dist-packages/zmes_hook_helpers/yolo.py", line 64, in detect
self.net = cv2.dnn.readNet(weights_file_abs_path,
cv2.error: OpenCV(4.3.0) /io/opencv/modules/dnn/src/darknet/darknet_io.cpp:821: error: (-212:Parsing error) Unsupported activation: mish in function 'ReadDarknetFromCfgStream'
I couldn’t find anything in this forum or through google which leads me to believe that I have a bigger permissions error than the inutile. Would you agree, or is there something else going on that I need to track down?
Posted: Fri Jul 10, 2020 11:38 pm
by asker
