zmninja iOS 13.4 update
sipi
Post by sipi »
I updated iOS on my iPhone then arrived an zmninja update and updated it too.
After this updates I didn't find my server in app (the configured servers are gone) and I can't setup it because can't be saved (nothing happens).
What happened?
Thank for your help.
asker
Re: zmninja iOS 13.4 update
Post by asker »
I'm not sure - I've started the update process to 13.4 to see if the new OS broke anything. Will update here.
Please read before posting:
ES docs
zmNinja docs
asker
Post by asker »
I just updated to iOS 13.4.1 and had no issues.
Do the following:
a) In zmNinja, clear API cache (Menu)
b) Exit the app
c) Go to ZoneMinder, to Options->API and click "Revoke all tokens"
d) Then run zmNinja
If you don't see your server, run Wizard (in my case, none of my settings were removed)
ES docs
zmNinja docs
sipi
Post by sipi »
thank you for your quickly answer but in the meantime, i upgraded to iOS 13.4.1 and nothing changed.
My server settings are gone and I can't create a new one. Unable to save server settings ... I click Save, but nothing happens. The configured server is not listed.
Thank you for your help.
asker
Post by asker »
Okay, try this:
1) Start zmNinja, go to settings, disable "Cloud backup", save
2) Exit app
3) Delete app from device
4) Install again
5) Use wizard
ES docs
zmNinja docs
sipi
Post by sipi »
thank you for your help, problem is solved.
Your advice for reinstall was successful.
Thank you for very quickly help and solution. Many thanks.
Kind Regards
asker
Post by asker »
Sounds good!
ES docs
zmNinja docs
