Login validated but API failed
Discussion topics related to mobile applications for ZoneMinder
detxm80
Post by detxm80 » Fri Mar 13, 2020 10:55 am
Hi guys,
i've a problem with my zonminder server and zmninja app. All ok by my pc, but if i want to set my zmninja app i get this error:
log:
Mar 13, 2020 11:52:14 AM INFO API login error {"status":-1,"error":"The operation couldn’t be completed. Protocol error"}
Mar 13, 2020 11:52:14 AM DEBUG ***  Inside native HTTP error for url:undefined
Mar 13, 2020 11:52:14 AM INFO Validating APIs at https://xxx.xx.xx/zm/api/host/getVersion.json?
Mar 13, 2020 11:52:14 AM DEBUG zmAutoLogin: Inside auth-error broadcast
Mar 13, 2020 11:52:14 AM INFO zmAutologin Error {"status":-1,"error":"The operation couldn’t be completed. Protocol error"} and status undefined
Mar 13, 2020 11:52:14 AM DEBUG Not intercepting as skipIntercept is true
Mar 13, 2020 11:52:14 AM INFO Recaptcha failed, but assuming ZM has recaptcha disabled
Mar 13, 2020 11:52:14 AM DEBUG Logging in using old web-scrape method
Mar 13, 2020 11:52:14 AM DEBUG obfuscate: original:5148 obfuscated:1321 scheme:lzs
Mar 13, 2020 11:52:14 AM INFO API based login not supported, need to use web scraping...
Mar 13, 2020 11:52:14 AM INFO Doing fresh login to ZM
thank you
Re: Login validated but API failed
Post by rockedge » Fri Mar 13, 2020 1:16 pm
what happens if you in a browser manually test the API with
https://xxx.xx.xx/zm/api/host/getVersion.json or http://xxx.xx.xx/zm/api/host/getVersion.json?
first open the ZM web console and login then try the above..you should see a response with the API and ZM version
Also what version of OS? version of zmNinja and version of ZM? Then lets go from there
detxm80
Post by detxm80 » Fri Mar 13, 2020 1:59 pm
Hi rockedge, thanks for your reply!
the response is:
{"version":"1.34.6","apiversion":"2.0"}
OS:
Distributor ID:	Ubuntu
Description:	Ubuntu 18.04.4 LTS
Release:	18.04
Codename:	bionic
on VM ON PROXMOX
PHONE OS:
ios 13.3.1
zmNinja version: 1.3.089
detxm80
Post by detxm80 » Fri Mar 13, 2020 6:27 pm
if a try this:
curl -XPOST -d "user=admin&pass=password" https://<ipaddress>/zm/api/host/getVersion.json
this is output:
curl: (60) SSL certificate problem: self signed certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above
Post by rockedge » Fri Mar 13, 2020 9:55 pm
I see, I think in the docs on the API the authorization methods are updated. Do you have the Options->System->OPT_USE_LEGACY_API_AUTH enabled?
Have you checked out https://zoneminder.readthedocs.io/en/1.32.3/api.html? It has some good tips for communicating with the API
gregthegeek
Post by gregthegeek » Wed Apr 22, 2020 8:00 pm
FYI I had this exact problem and could not get zmNinja working with a new ZM install. I setup my own SSL certs and then everything started to work fine. I didn't find this thread till now or I would have tried the legacy api auth option first, but I still wanted my own cert anyway.
Users browsing this forum: No registered users and 6 guests
