Can somebody help me with this error?
When I run this command to test the event server manual "sudo -u www-data ./zmeventnotification.pl --config ./zmeventnotification.ini"
Thanks!
Zmninja Certification error
- Snap6.png (668.61 KiB) Viewed 9481 times
- Snap4.png (227.36 KiB) Viewed 9481 times
Re: Zmninja Certification error
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
thanks for the reply.
So my settings are correct?
I tried this but still the same issue.
For this scenario, this should have been enough!
sudo chown -R www-data:root /etc/letsencrypt/
I did above and the manual start was working fine.
Ok now its working.
So I did the test and I got the "Tick end" message.
I opened ZMninja on my phone its asked it was allowed to send notification. "I approved".
But still no notifications on my phone.
ES docs
zmNinja docs
ES docs
zmNinja docs
Did some more checks.
Looks like I don’t have the tokens.txt file.
How can I fix that?
Thanks!
Kind regards,
How can I fix that?
Thanks!
Kind regards,
tokens.txt is created when mobile phones running zmNinja register with the ES.
If that is not happening, your zmNinja mobile app is not able to connect to the ES. Check debug logs on both sides when zmNinja starts.
ES docs
zmNinja docs
ES docs
zmNinja docs
