While being logged in zm console as the same user as zmninja
https://gist.github.com/tombu2130/ad61c ... ed56d30a73
2020-01-11 20:27:11.052672 zmeventnotification[11127].INF [main:619] [using config file: /etc/zm/zmeventnotification.ini]
2020-01-11 20:27:11.089777 zmeventnotification[11127].INF [main:619] [using secrets file: /etc/zm/secrets.ini]
2020-01-11 20:27:11.125606 zmeventnotification[11127].INF [main:619] [ES will be restarted at 10800 seconds]
2020-01-11 20:27:11.303092 zmeventnotification[11127].INF [main:619] [Push enabled via FCM]
2020-01-11 20:27:11.334013 zmeventnotification[11127].INF [main:619] [MQTT Disabled]
2020-01-11 20:27:11.384002 zmeventnotification[11127].INF [main:619] [You are running version: 4.7]
Can't ignore signal CHLD, forcing to default.
2020-01-11 20:27:11.575384 zmeventnotification[11127].INF [main:619] [Event Notification daemon v 4.7 starting]
2020-01-11 20:27:11.603146 zmeventnotification[11127].INF [main:619] [Initializing FCM tokens...]
2020-01-11 20:27:11.636336 zmeventnotification[11127].INF [main:619] [Total event client connections: 3]
2020-01-11 20:27:11.693740 zmeventnotification[11127].INF [main:619] [Reloading Monitors...]
2020-01-11 20:27:11.726102 zmeventnotification[11127].INF [main:619] [Re-loading monitors, emptying needsReload() list]
2020-01-11 20:27:11.761545 zmeventnotification[11127].INF [main:619] [About to start listening to socket]
2020-01-11 20:27:11.796699 zmeventnotification[11127].INF [main:619] [Secure WS(WSS) is enabled...]
2020-01-11 20:27:11.834880 zmeventnotification[11127].INF [main:619] [Web Socket Event Server listening on port 9000]
2020-01-11 20:29:13.476396 zmeventnotification[11127].INF [main:619] [got a websocket connection from ::ffff:162.208.37.32 (3) active connections]
2020-01-11 20:29:13.514892 zmeventnotification[11127].INF [main:619] [Websockets: New Connection Handshake requested from ::ffff:162.208.37.32:59117 state=pending auth, id=1578799753.51463]
bad bcrypt settings at /usr/bin/zmeventnotification.pl line 942.
