Seeing these errors in the log
2016-01-28 14:50:13.604723 web_js 4136 ERR getStreamCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-856375w.sock ) failed: Permission denied - checkStreamForErrors() ?view=watch
2016-01-28 14:50:13.574494 web_php 4136 ERR socket_bind( /var/lib/zoneminder/sock/zms-856375w.sock ) failed: Permission denied /usr/share/zoneminder/www/includes/functions.php 2330
2016-01-28 14:50:07.708086 web_js 4136 ERR Uncaught TypeError: Cannot read property 'delayed' of undefined http://zonemndr.v.rotech.ca/zm/skins/classic/views/js/watch.js 234
2016-01-28 14:50:03.562313 web_js 4136 ERR getStreamCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-856375w.sock ) failed: Permission denied - checkStreamForErrors() ?view=watch
2016-01-28 14:50:03.529453 web_php 4136 ERR socket_bind( /var/lib/zoneminder/sock/zms-856375w.sock ) failed: Permission denied /usr/share/zoneminder/www/includes/functions.php 2330
2016-01-28 14:49:57.970272 zms 10191 ERR Unable to validate swap image path, disabling buffered playback /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 3966
2016-01-28 14:49:57.969942 zms 10191 ERR Can't mkdir /dev/shm/zmswap-m3: Permission denied /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 3448
2016-01-28 14:49:57.954573 zms 10191 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor CAM1 /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 426
2016-01-28 14:34:07.474674 zmc_m3 7937 INF CAM1: 1000 - Capturing at 0.99 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
Tried changing from Monitor to MoDetect, and still get a video stream, but no recording is triggered.
Tried setting it to record... "recorded" for a minute. Shut it off, says there is one event, seventy seconds long. Fine - but clicking on the event brings up an empty video window. (pic icon with X ) I'm guessing something doesn't have correct write permissions?
Latest log events now look like
2016-01-28 15:13:05.703000 web_js 12240 ERR getCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied - checkStreamForErrors() ?view=event
2016-01-28 15:13:05.674115 web_php 12240 ERR socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied /usr/share/zoneminder/www/includes/functions.php 2330
2016-01-28 15:13:04.180378 web_js 12240 ERR getCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied - checkStreamForErrors() ?view=event
2016-01-28 15:13:04.150826 web_php 12240 ERR socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied /usr/share/zoneminder/www/includes/functions.php 2330
2016-01-28 15:13:00.177339 web_js 12240 ERR getCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied - checkStreamForErrors() ?view=event
2016-01-28 15:13:00.144194 web_php 12240 ERR socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied /usr/share/zoneminder/www/includes/functions.php 2330
2016-01-28 15:12:45.841345 web_js 7709 ERR getCmdResponse stream error: socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied - checkStreamForErrors() ?view=event
2016-01-28 15:12:45.817149 web_php 7709 ERR socket_bind( /var/lib/zoneminder/sock/zms-246763w.sock ) failed: Permission denied /usr/share/zoneminder/www/includes/functions.php 2330
2016-01-28 15:12:45.523985 zms 12244 ERR Empty JPEG image (DNL not supported) /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2016-01-28 15:12:45.523755 zms 12244 ERR Attempt to directly assign buffer with invalid width or height: 0 0 /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 360
2016-01-28 15:12:45.523558 zms 12244 ERR Attempt to assign image with an empty buffer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 467
2016-01-28 15:12:45.523207 zms 12244 ERR Can't open /usr/share/zoneminder/www/events/3/16/01/28/15/11/22/00001-capture.jpg: Permission denied /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 669
2016-01-28 15:12:45.507521 zms 12244 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor CAM1 /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 426
2016-01-28 15:12:45.382564 web_js 10913 WAR Adjusting to minimum height when getting popup size for tag 'event' - getPopupSize() ?view=events
2016-01-28 15:12:34.007920 zmdc 2885 WAR Can't find process with command of 'zma -m 3' zmdc.pl
2016-01-28 15:12:33.850100 zmdc 2885 WAR Can't find process with command of 'zmtrack.pl -m 3' zmdc.pl
2016-01-28 15:12:33.689170 zmdc 2885 INF 'zmc -m 3' already running at 16/01/28 14:17:14, pid = 7937 zmdc.pl
