How can I setup serial RS 422 PTZ in ZM
Zmptz
Re: How can I setup serial RS 422 PTZ in ZM
Post by Zmptz »
I've ran this command:
sudo /usr/bin/zmcontrol.pl --panspeed=35 --autostop --command=moveConRight --id=4
and the output i get is nothing.
Zmptz
Post by Zmptz »
Zmptz
Post by Zmptz »
Update:
I've found out in the PelcoP.pm script the first couple line the script was referring to Pelco D after immediate changing this. I had the dainostic leds woking again but no movement. Next I changed the comm port to :
stty 4800 -cstopb cs8 -parenb -crtscts -echo -F /dev/ttyS0
stty -a -F /dev/ttyS0speed 4800 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>;
eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R;
werase = ^W; lnext = ^V; flush = ^O; min = 0; time = 244;
-parenb -parodd -cmspar cs8 hupcl -cstopb cread clocal -crtscts
ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff
-iuclc -ixany -imaxbel -iutf8
-opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
-isig -icanon -iexten -echo -echoe -echok -echonl -noflsh -xcase -tostop -echoprt
-echoctl -echoke
Still getting the same results.
I can use cutecom to control the cam successfully with the serial set to 4800, Parity None, Stopbit 1, 8 bit. but nothing from Zoneminder.
Heres my standard Pelcop.pm from directory /usr/share/perl5/ZoneMinder/Control/PelcoP.pm
# ZoneMinder Pelco-P Control Protocol Module, $Date$, $Revision$
# Copyright (C) 2001-2008  Philip Coombes
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module contains the implementation of the Pelco-P camera control
# protocol
package ZoneMinder::Control::PelcoP;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Pelco-P Control Protocol
use Time::HiRes qw( usleep );
use constant STX => 0xa0;
use constant ETX => 0xaf;
use constant COMMAND_GAP => 100000; # In ms
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use Device::SerialPort;
    $self->{port} = new Device::SerialPort( $self->{Monitor}->{ControlDevice} );
    $self->{port}->baudrate(4800);
    $self->{port}->databits(8);
    $self->{port}->parity('none');
    $self->{port}->stopbits(1);
    $self->{port}->handshake('none');
    $self->{port}->read_const_time(50);
    $self->{port}->read_char_time(10);
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
    $self->{port}->close();
sub printMsg
    if ( logDebugging() )
        my $self = shift;
        my $msg = shift;
        my $prefix = shift || "";
        $prefix = $prefix.": " if ( $prefix );
        my $line_length = 16;
        my $msg_len = int(@$msg);
        my $msg_str = $prefix;
        for ( my $i = 0; $i < $msg_len; $i++ )
            if ( ($i > 0) && ($i%$line_length == 0) && ($i != ($msg_len-1)) )
                $msg_str .= sprintf( "\n%*s", length($prefix), "" );
            $msg_str .= sprintf( "%02x ", $msg->[$i] );
        $msg_str .= "[".$msg_len."]";
        Debug( $msg_str );
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $ack = shift || 0;
    my $result = undef;
    my $checksum = 0x00;
    for ( my $i = 1; $i < int(@$cmd); $i++ )
        $checksum ^= $cmd->[$i];
    $checksum &= 0xff;
    push( @$cmd, $checksum );
    $self->printMsg( $cmd, "Tx" );
    my $id = $cmd->[0] & 0xf;
    my $tx_msg = pack( "C*", @$cmd );
    #print( "Tx: ".length( $tx_msg )." bytes\n" );
    my $n_bytes = $self->{port}->write( $tx_msg );
    if ( !$n_bytes )
        Error( "Write failed: $!" );
    if ( $n_bytes != length($tx_msg) )
        Error( "Incomplete write, only ".$n_bytes." of ".length($tx_msg)." written: $!" );
    if ( $ack )
        Debug( "Waiting for ack" );
        my $max_wait = 3;
        my $now = time();
        while( 1 )
            my ( $count, $rx_msg ) = $self->{port}->read(4);
            if ( $count )
                #print( "Rx1: ".$count." bytes\n" );
                my @resp = unpack( "C*", $rx_msg );
                printMsg( \@resp, "Rx" );
                if ( $resp[0] = 0x80 + ($id<<4) )
                    if ( ($resp[1] & 0xf0) == 0x40 )
                        my $socket = $resp[1] & 0x0f;
                        Debug( "Got ack for socket $socket" );
                        $result = !undef;
                    else
                        Error( "Got bogus response" );
                    last;
                else
                    Error( "Got message for camera ".(($resp[0]-0x80)>>4) );
            if ( (time() - $now) > $max_wait )
                Warning( "Response timeout" );
                last;
sub remoteReset
    my $self = shift;
    Debug( "Remote Reset" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0f, 0x00, 0x00, ETX );
    $self->sendCmd( \@msg );
sub resetDefaults
    my $self = shift;
    Debug( "Reset Defaults" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x29, 0x00, 0x00, ETX );
sub cameraOff
    my $self = shift;
    Debug( "Camera Off" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x08, 0x00, 0x00, 0x00, ETX );
sub cameraOn
    my $self = shift;
    Debug( "Camera On" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x88, 0x00, 0x00, 0x00, ETX );
sub autoScan
    my $self = shift;
    Debug( "Auto Scan" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x90, 0x00, 0x00, 0x00, ETX );
sub manScan
    my $self = shift;
    Debug( "Manual Scan" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x10, 0x00, 0x00, 0x00, ETX );
sub stop
    my $self = shift;
    Debug( "Stop" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x00, 0x00, 0x00, ETX );
sub moveConUp
    my $self = shift;
    my $params = shift;
    my $speed = $self->getParam( $params, 'tiltspeed' );
    my $autostop = $self->getParam( $params, 'autostop', 0 );
    Debug( "Move Up" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x08, 0x00, $speed, ETX );
    if( $autostop && $self->{Monitor}->{AutoStopTimeout} )
        usleep( $self->{Monitor}->{AutoStopTimeout} );
        $self->stop( $params );
sub moveConDown
    my $self = shift;
    my $params = shift;
    Debug( "Move Down" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x10, 0x00, $speed, ETX );
        $self->stop();
sub moveConLeft
    my $self = shift;
    my $params = shift;
    my $speed = $self->getParam( $params, 'panspeed' );
    Debug( "Move Left" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x04, $speed, 0x00, ETX );
        $self->stop();
sub moveConRight
    my $self = shift;
    my $params = shift;
    Debug( "Move Right" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x02, $speed, 0x00, ETX );
        $self->stop();
sub moveConUpLeft
    my $self = shift;
    my $params = shift;
    my $panspeed = $self->getParam( $params, 'panspeed', 0x3f );
    my $tiltspeed = $self->getParam( $params, 'tiltspeed', 0x3f );
    Debug( "Move Up/Left" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0c, $panspeed, $tiltspeed, ETX );
        $self->stop();
sub moveConUpRight
    my $self = shift;
    my $params = shift;
    Debug( "Move Up/Right" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0a, $panspeed, $tiltspeed, ETX );
        $self->stop();
sub moveConDownLeft
    my $self = shift;
    my $params = shift;
    Debug( "Move Down/Left" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x14, $panspeed, $tiltspeed, ETX );
        $self->stop();
sub moveConDownRight
    my $self = shift;
    my $params = shift;
    Debug( "Move Down/Right" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x12, $panspeed, $tiltspeed, ETX );
        $self->stop();
sub moveStop
    my $self = shift;
    Debug( "Move Stop" );
    $self->stop();
sub flip180
    my $self = shift;
    Debug( "Flip 180" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x21, ETX );
sub zeroPan
    my $self = shift;
    Debug( "Zero Pan" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x22, ETX );
sub _setZoomSpeed
    my $self = shift;
    my $speed = shift;
    Debug( "Set Zoom Speed $speed" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x25, 0x00, $speed, ETX );
sub zoomStop
    my $self = shift;
    Debug( "Zoom Stop" );
    $self->stop();
    $self->_setZoomSpeed( 0 );
sub zoomConTele
    my $self = shift;
    my $params = shift;
    my $speed = $self->getParam( $params, 'speed', 0x01 );
    Debug( "Zoom Tele" );
    $self->_setZoomSpeed( $speed );
    usleep( COMMAND_GAP );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x20, 0x00, 0x00, ETX );
        $self->zoomStop();
sub zoomConWide
    my $self = shift;
    my $params = shift;
    Debug( "Zoom Wide" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x40, 0x00, 0x00, ETX );
        $self->zoomStop();
sub _setFocusSpeed
    my $self = shift;
    my $speed = shift;
    Debug( "Set Focus Speed $speed" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x27, 0x00, $speed, ETX );
sub focusConNear
    my $self = shift;
    my $params = shift;
    my $speed = $self->getParam( $params, 'speed', 0x03 );
    Debug( "Focus Near" );
    $self->_setFocusSpeed( $speed );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x01, 0x00, 0x00, 0x00, ETX );
        $self->_setFocusSpeed( 0 );
sub focusConFar
    my $self = shift;
    my $params = shift;
    Debug( "Focus Far" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x80, 0x00, 0x00, ETX );
sub focusStop
    my $self = shift;
    Debug( "Focus Stop" );
    $self->stop();
sub focusAuto
    my $self = shift;
    Debug( "Focus Auto" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x00, ETX );
sub focusMan
    my $self = shift;
    Debug( "Focus Man" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x02, ETX );
sub _setIrisSpeed
    my $self = shift;
    my $speed = shift;
    Debug( "Set Iris Speed $speed" );
sub irisConClose
    my $self = shift;
    my $params = shift;
    Debug( "Iris Close" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x04, 0x00, 0x00, 0x00, ETX );
        $self->_setIrisSpeed( 0 );
sub irisConOpen
    my $self = shift;
    my $params = shift;
    Debug( "Iris Open" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x02, 0x80, 0x00, 0x00, ETX );
sub irisStop
    my $self = shift;
    Debug( "Iris Stop" );
    $self->stop();
sub irisAuto
    my $self = shift;
    Debug( "Iris Auto" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x00, ETX );
sub irisMan
    my $self = shift;
    Debug( "Iris Man" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x02, ETX );
sub writeScreen
    my $self = shift;
    my $params = shift;
    my $string = $self->getParam( $params, 'string' );
    Debug( "Writing '$string' to screen" );
    my @chars = unpack( "C*", $string );
    for ( my $i = 0; $i < length($string); $i++ )
        my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x15, $i, $chars[$i], ETX );
sub clearScreen
    my $self = shift;
    Debug( "Clear Screen" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x17, 0x00, 0x00, ETX );
sub clearPreset
    my $self = shift;
    my $params = shift;
    my $preset = $self->getParam( $params, 'preset', 1 );
    Debug( "Clear Preset $preset" );
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x05, 0x00, $preset, ETX );
sub presetSet
    my $self = shift;
    my $params = shift;
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x03, 0x00, $preset, ETX );
sub presetGoto
    my $self = shift;
    my $params = shift;
    my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, $preset, ETX );
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
sub reset
    my $self = shift;
    Debug( "Reset" );
    $self->remoteReset();
    $self->resetDefaults();
sub wake
    my $self = shift;
    Debug( "Wake" );
    $self->cameraOn();
sub sleep
    my $self = shift;
    Debug( "Sleep" );
    $self->cameraOff();
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
  use ZoneMinder::Database;
  blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
Zoneminder settings are:
Device Path /dev/video0
Capture Method Video For Linux version 2
Device Channel 1
Device Format PAL
Capture Palette Auto
Multi Buffering Use Config Value
Captures Per Frame
25
Target Colorspace 24 bit
Capture Width (pixels)
640
Capture Height (pixels)
480
Preserve Aspect Ratio
Orientation NO
Deinterlacing NO
Controllable
Control Type Pelco-P Edit
Control Device /dev/ttyS0
Control Address 0 ( I tried both 0 and 1 My camera physical address is set to 1)
Auto Stop Timeout 0.50
Track Motion NO
Track Delay 0
Return Location None
Return Delay 0
Please Please Please help!!!!!!
AndyNY
Post by AndyNY »
If your Control Address is still set to zero, try setting it to one. Each PTZ camera has a way to set it's control address so you can control more than one from the same interface. There is no zero on any camera I have used, most default to one.
Zmptz
Post by Zmptz »
Thanks for your reply
I've set the Control address to 0,1,2 and 3. The camera Address is set to 1
I read somewhere on this forum that Pelco D and P add +1 to the address??
In a serial terminal software I can send theses command to control the camera.
Pan Left at normal speed: A0 00 00 04 20 00 AF 2B
Pan Right at normal speed: A0 00 00 02 20 00 AF 2D
Tilt Up at normal speed: A0 00 00 08 00 20 AF 27
Tilt Down at normal speed: A0 00 00 10 00 20 AF 3F
Stop all actions (Pan/Tilt/Zoom/Iris etc.): A0 00 00 00 00 00 AF 0F
AndyNY
Post by AndyNY »
Zmptz wrote:Thanks for your reply
I am using Pelco-D and my camera is set to 1, same as ZM.
Are you saying that when you send with the terminal s/w it works, but not from ZM?
Actually, I didn't see in this thread where you checked the permissions. What group is /dev/ttyS0? Usually it's dialup, make sure it is rw, and that your web server user (www-data) is in the group dialup. I realize you may have checked it already, but if you are running the terminal s/w as root and it works, it may be the issue. Try su - www-data and see if the terminal method still works to rule that out.
You can also add some debugging to zmcontrol.pl - just add:
Info($var);
which will write to /var/log/messages. You are obviously close.
Zmptz
Post by Zmptz »
I've changed the address to 1
done the following commands
ls -l /dev/ttyS0
crw-rw---- 1 root dialout 4, 64 Dec 31 19:47 /dev/ttyS0
Next I sent this command to Pan right
sudo -u www-data zmcontrol.pl --id=4 --panspeed=32 --command=moveConRight
sudo -u www-data zmcontrol.pl --id=4 --panspeed=32 --command=moveConLeft
In return Nothing moved and no error on the log within ZM
how do you add debugging when i add Info($var); to the command above i get a -bash error
sudo -u www-data zmcontrol.pl -info($var); --id=4 --panspeed=32 --command=moveConLeft
-bash: syntax error near unexpected token `('
I know might be doing something wrong here. :?:
AndyNY
Post by AndyNY »
Zmptz wrote:Thanks
Yeah, I actually meant you can edit zmcontrol.pl and substitute one of the program variables for $var. I tend to forget not everyone is a programmer :D
Other than that, it looks like you are doing everything exactly right...
Zmptz
Post by Zmptz »
At the moment my zmcontrol.pl script looks like this:
#!/usr/bin/perl -wT
# ZoneMinder Control Script, $Date$, $Revision$
# This script continuously monitors the recorded events for the given
# monitor and applies any filters which would delete and/or upload
# matching events
use strict;
use lib '/usr/share/perl/5.20.2'; # Include custom perl install path
use ZoneMinder;
use Getopt::Long;
use POSIX qw/strftime EPIPE/;
use Socket;
#use Data::Dumper;
use Module::Load::Conditional qw{can_load};;
use constant MAX_CONNECT_DELAY => 10;
use constant MAX_COMMAND_WAIT => 1800;
$| = 1;
$ENV{PATH}  = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
    print( "
Usage: zmcontrol.pl --id <monitor_id> --command=<command> <various options>
    exit();
logInit();
my $arg_string = join( " ", @ARGV );
my $id;
my %options;
if ( !GetOptions(
    'id=i'=>\$id,
    'command=s'=>\$options{command},
    'xcoord=i'=>\$options{xcoord},
    'ycoord=i'=>\$options{ycoord},
    'speed=i'=>\$options{speed},
    'step=i'=>\$options{step},
    'panspeed=i'=>\$options{panspeed},
    'tiltspeed=i'=>\$options{tiltspeed},
    'panstep=i'=>\$options{panstep},
    'tiltstep=i'=>\$options{tiltstep},
    'preset=i'=>\$options{preset},
    'autostop'=>\$options{autostop},
    Usage();
if ( !$id || !$options{command} )
    print( STDERR "Please give a valid monitor id and command\n" );
    Usage();
( $id ) = $id =~ /^(\w+)$/;
Debug( $arg_string );
my $sock_file = $Config{ZM_PATH_SOCKS}.'/zmcontrol-'.$id.'.sock';
socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
my $saddr = sockaddr_un( $sock_file );
my $server_up = connect( CLIENT, $saddr );
if ( !$server_up )
    # The server isn't there
    my $monitor = zmDbGetMonitorAndControl( $id );
    if ( !$monitor )
        Fatal( "Unable to load control data for monitor $id" );
    my $protocol = $monitor->{Protocol};
    if ( -x $protocol )
        # Protocol is actually a script!
        # Holdover from previous versions
        my $command .= $protocol.' '.$arg_string;
        Debug( $command."\n" );
        my $output = qx($command);
        my $status = $? >> 8;
        if ( $status || logDebugging() )
            chomp( $output );
            Debug( "Output: $output\n" );
        if ( $status )
            Error( "Command '$command' exited with status: $status\n" );
            exit( $status );
        exit( 0 );
    Info( "Starting control server $id/$protocol" );
    close( CLIENT );
	if ( ! can_load( modules => { "ZoneMinder::Control::$protocol" => undef } ) ) {
		Fatal("Can't load ZoneMinder::Control::$protocol");
    if ( my $cpid = fork() )
        logReinit();
        # Parent process just sleep and fall through
        socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or die( "Can't open socket: $!" );
        my $attempts = 0;
        while (!connect( CLIENT, $saddr ))
            $attempts++;
            Fatal( "Can't connect: $!" ) if ($attempts > MAX_CONNECT_DELAY);
            sleep(1);
    elsif ( defined($cpid) )
        close( STDOUT );
        close( STDERR );
        setpgrp();
        logReinit();
        Info( "Control server $id/$protocol starting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
        $0 = $0." --id $id";
        my $control = "ZoneMinder::Control::$protocol"->new( $id );
        my $control_key = $control->getKey();
        $control->loadMonitor();
        $control->open();
        socket( SERVER, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
        unlink( $sock_file );
        bind( SERVER, $saddr ) or Fatal( "Can't bind: $!" );
        listen( SERVER, SOMAXCONN ) or Fatal( "Can't listen: $!" );
        my $rin = '';
        vec( $rin, fileno(SERVER), 1 ) = 1;
        my $win = $rin;
        my $ein = $win;
        my $timeout = MAX_COMMAND_WAIT;
        while( 1 )
            my $nfound = select( my $rout = $rin, undef, undef, $timeout );
            if ( $nfound > 0 )
                if ( vec( $rout, fileno(SERVER), 1 ) )
                    my $paddr = accept( CLIENT, SERVER );
                    my $message = <CLIENT>;
                    next if ( !$message );
                    my $params = jsonDecode( $message );
                    #Debug( Dumper( $params ) );
                    my $command = $params->{command};
                    $control->$command( $params );
                    close( CLIENT );
                else
                    Fatal( "Bogus descriptor" );
            elsif ( $nfound < 0 )
                if ( $! == EPIPE )
                    Error( "Can't select: $!" );
                else
                    Fatal( "Can't select: $!" );
            else
                #print( "Select timed out\n" );
                last;
        Info( "Control server $id/$protocol exiting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
        $control->close();
        exit( 0 );
    else
        Fatal( "Can't fork: $!" );
# The server is there, connect to it
#print( "Writing commands\n" );
CLIENT->autoflush();
my $message = jsonEncode( \%options );
print( CLIENT $message );
shutdown( CLIENT, 1 );
exit( 0 );
where do i enter or edit $var?
I'm just a engineer :D
Zmptz
Post by Zmptz »
Hello Happy New Year.
Right back to work.
So I managed to set Debugging via the option logging route. this is what i found out.
Tx: a0 01 00 00 00 00 af ae [8]	zmcontrol.pl
2016-01-02 11:18:47.476110	zmcontrol	13787	DBG	Stop	zmcontrol.pl
2016-01-02 11:18:46.919110	zmcontrol	13787	DBG	Tx: a0 01 00 04 1b 00 af b1 [8]	zmcontrol.pl
2016-01-02 11:18:46.861080	zmcontrol	13787	DBG	Move Left	zmcontrol.pl
2016-01-02 11:18:46.195870	zmcontrol	13787	DBG	Tx: a0 01 00 00 00 00 af ae [8]	zmcontrol.pl
2016-01-02 11:18:46.139910	zmcontrol	13787	DBG	Stop	zmcontrol.pl
2016-01-02 11:18:45.583770	zmcontrol	13787	DBG	Tx: a0 01 00 10 00 25 af 9b [8]	zmcontrol.pl
2016-01-02 11:18:45.535750	zmcontrol	13787	DBG	Move Down	zmcontrol.pl
2016-01-02 11:18:44.849310	zmcontrol	13787	DBG	Tx: a0 01 00 00 00 00 af ae [8]	zmcontrol.pl
2016-01-02 11:18:44.804430	zmcontrol	13787	DBG	Stop	zmcontrol.pl
2016-01-02 11:18:44.259450	zmcontrol	13787	DBG	Tx: a0 01 00 02 1b 00 af b7 [8]	zmcontrol.pl
2016-01-02 11:18:44.220340	zmcontrol	13787	DBG	Move Right	zmcontrol.pl
2016-01-02 11:18:43.858370	zmcontrol	13787	DBG	Tx: a0 01 00 00 00 00 af ae [8]	zmcontrol.pl
2016-01-02 11:18:43.802410	zmcontrol	13787	DBG	Stop	zmcontrol.pl
2016-01-02 11:18:43.246280	zmcontrol	13787	DBG	Tx: a0 01 00 08 00 16 af b0 [8]	zmcontrol.pl
2016-01-02 11:18:43.190940	zmcontrol	13787	DBG	Move Up	zmcontrol.pl
2016-01-02 11:09:13.819150	zmcontrol	13787	DBG	Tx: a0 01 00 00 00 00 af ae [8]
Pan Left at normal speed: A0 00 00 04 20 00 AF 2B (what it should be) = (what ZM is sending out) a0 01 00 04 1b 00 af b1 [8]
Pan Right at normal speed: A0 00 00 02 20 00 AF 2D (what it should be) = (what ZM is sending out) a0 01 00 02 1b 00 af b7 [8
Tilt Up at normal speed: A0 00 00 08 00 20 AF 27 (what it should be) = (what ZM is sending out) a0 01 00 08 00 16 af b0 [8]
Tilt Down at normal speed: A0 00 00 10 00 20 AF 3F (what it should be) = (what ZM is sending out) a0 01 00 10 00 25 af 9b
Stop all actions (Pan/Tilt/Zoom/Iris etc.): A0 00 00 00 00 00 AF 0F = a0 01 00 00 00 00 af ae [8]
now according to this:
Byte 1 STX
Byte 2 Camera Address
Byte 3 Data 1
Byte 4 Data 2
Byte 5 Data 3
Byte 6 Data 4
Byte 7 ETX
Byte 8 Checksum
Byte 1 (STX) - Start of Text, fixed to A0
Byte 2 (Camera Address) - logical address of the camera being controlled (Address 1 is 00)
Byte 3 & 6 (Data 1 to 4) - see http://www.commfront.com/rs232_examples ... orial2.htm second table.
Byte 7 (ETX) - End of Text, fixed to AF
Byte 8 (Checksum) - xOR sum of Bytes 1 to 7
This shows byte 2 the camera address ZM add +1 which mean I need to set it to 0. its now giving this result.
Tx: a0 00 00 00 00 00 af af [8]	zmcontrol.pl
2016-01-02 11:30:24.627610	zmcontrol	13932	DBG	Stop	zmcontrol.pl
2016-01-02 11:30:24.071370	zmcontrol	13932	DBG	Tx: a0 00 00 04 19 00 af b2 [8]	zmcontrol.pl
2016-01-02 11:30:24.015500	zmcontrol	13932	DBG	Move Left	zmcontrol.pl
2016-01-02 11:30:23.959360	zmcontrol	13932	DBG	Tx: a0 00 00 00 00 00 af af [8]	zmcontrol.pl
2016-01-02 11:30:23.903320	zmcontrol	13932	DBG	Stop	zmcontrol.pl
2016-01-02 11:30:23.347280	zmcontrol	13932	DBG	Tx: a0 00 00 10 00 1d af a2 [8]	zmcontrol.pl
2016-01-02 11:30:23.291380	zmcontrol	13932	DBG	Move Down	zmcontrol.pl
2016-01-02 11:30:23.235270	zmcontrol	13932	DBG	Tx: a0 00 00 00 00 00 af af [8]	zmcontrol.pl
2016-01-02 11:30:23.179260	zmcontrol	13932	DBG	Stop	zmcontrol.pl
2016-01-02 11:30:22.623080	zmcontrol	13932	DBG	Tx: a0 00 00 02 27 00 af 8a [8]	zmcontrol.pl
2016-01-02 11:30:22.567310	zmcontrol	13932	DBG	Move Right	zmcontrol.pl
2016-01-02 11:30:22.511140	zmcontrol	13932	DBG	Tx: a0 00 00 00 00 00 af af [8]	zmcontrol.pl
2016-01-02 11:30:22.455150	zmcontrol	13932	DBG	Stop	zmcontrol.pl
2016-01-02 11:30:21.898970	zmcontrol	13932	DBG	Tx: a0 00 00 08 00 22 af 85 [8]	zmcontrol.pl
2016-01-02 11:30:21.842220	zmcontrol	13932	DBG	Move Up
Notice the coding is some what off on the PelcoP.pm file posted eariler.
Zmptz
Post by Zmptz »
can someone help?
Zmptz
Post by Zmptz »
Not sure if the checksum is correct, but I need it to be xOr byte 1 through to 7 can anyone verify this above?
Zmptz
Post by Zmptz »
Please anyone programmer really struggling here
Zmptz
Post by Zmptz »
why does the PelcoP script generate an AF checksum instead of 0F on the Stop command
ZM stop all action
Operands format Hex and Operator xOr
a0 00 00 00 00 00 af 0f
any smart guy who can solve this problem.
Zmptz
Post by Zmptz »
greeting again.
I found what's happening with the checksum and how its being calculated.
for example Move Right
A0,00,00,02,08,00,AF, = checksum 05 if I manually type this it will work it moves to the right slowly
however the reality with PelcoP.pm in Zoneminder it calculates the checksum differently giving a different checksum.
00,00,02,08,00,AF = Checksum A5 this does Not work if entered manually.
So all i need to do is add the STX into the formula to make it work.
Anyone know how?
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    $checksum &= 0xff;
    if ( !$n_bytes )
    if ( $ack )
        my $max_wait = 3;
        my $now = time();
        while( 1 )
            if ( $count )
                        $result = !undef;
                    else
                    last;
                else
                last;
