SQL Error
Biggus
SQL Error
Post by Biggus »
I am receiving the following error message when starting up Zoneminder, how can I fix. It use to be OK then got this OK.
Unable to connect to ZM db.SQLSTATE[HY000] [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)
Using Ubuntu 14.04
Re: SQL Error
Is mysql installed and running?
e.g.
service mysql status
Biggus
Re: SQL Error
Post by Biggus »
I'm not sure what happened mysql appeared to screw up and I don't have the knowlege on how to fix so I've end up re-building the machine.
