I want to have a specific setup. My main ZoneMinder machine will be Debian it will have a few cameras plugged into it. I also have an Ubuntu machine and a Windows machine with cameras on them. Is it possible to have the Ubuntu and Windows machine serve streams to the main Debian machine? I don't want to have any UI or Web access to the cameras on the Ubuntu and Windows machines. I'm fine running a service other than ZoneMinder on those machines. I effectively need those machines to act as network cameras. Is this possible?
Thanks,
DaAwesomeP
One computer serving cameras to main server?
- DaAwesomeP
Re: One computer serving cameras to main server?
USB cameras on those PC's? Try to use VLC to stream camera output to zm.
- DaAwesomeP
Thanks! I like that idea. I'll report back here after I get everything set up. Yeah, they'll be V4L compatible cameras. I like the VLC idea. I could make that into a startup script. One camera per port.bbunge wrote:USB cameras on those PC's? Try to use VLC to stream camera output to zm.
There are several ways, but what you do is set that machine up to capture video from each camera and stream it on a chosen URI/port.
VLC is one way, mjpg-streamer is another, I think also ffmpeg can be used.
I use Zoneminder on several machines that a central machine collects the camera streams from. So Zoneminder to Zoneminder, with the central machine not actually connected to any camera itself. I use the path like /cgi-bin/nph-zms?mode=jpeg&monitor=1&scale=100&maxfps=5&buffer=1000&connkey=927436&rand=1442852046 with the remote host the url to the zoneminder machine "zoneminder.example.org" or subnet IP.
