Change console colours?
roadster
Post by roadster »
Hi there...
Is it possible to change the consoles background colour from white to black or anything else?
I intend to use a tablet pc near my bed where I can see cycle or montage when I can´t sleep...
The white background is a little annoying when the room is dark and the lights are out.
Cheers
Roadster
Nerre
Re: Change console colours?
Post by Nerre »
The look of zoneminders windows is controlled by CSS, though I'm not sure which file is best to edit. I'd probably try editing the skins, but it looks as if background is defined in reset.css.
roadster
Post by roadster »
Thanks a lot,
I was searching yesterdaa after starting this thread, shame on me... I a similar already solved problem...
Now I am going to edit the files after I have found them, I always forget where they are stored in my opensuse distro.
Cheers,
Roadster
JoaoAbreu
Post by JoaoAbreu »
roadster wrote:Thanks a lot,
Cheers,
Roadster
Can you tell me what opensuse distro are you using.
I am a novice that is having problems starting ZoneMinder in OpenSUSE 13.1.
Are you using MySQL or MariaDB?
roadster
Post by roadster »
I am using MySQL in OpenSuSE 13.1 as well
