Got it working with libvlc
This time I built the .deb package and installed it with dpkg and everything is working. I guess the make install script just doesn't put everything where it belongs.
Thanks for everyone's help
Problem with EasyN H3-V10R Wi-Fi Camera
Re: Problem with EasyN H3-V10R Wi-Fi Camera
Glad to hear you got it sorted!
Does your IR night vision work? If so did you have to enable it via the easyN software? I am having no joy with my night vision and I would like to avoid sending it back over the pond at my expense, if I dont have too...
Cheers,
Jon
Cheers,
Jon
My night vision worked straight out of the box. I haven't seen any configuration parameters to enable or disable it, so yours may be defective.
Again, thanks for the help with the configuration.
