zoneminder service is disabled
I'm using a breand new installation of Fedora 20/
The service will not start - mariadb is enabled but mysqld is not enabled. I wonder if that has something to do with the problem. If that is the problem how would I fix it, and if not, What IS the problem?
COMMAND: systemctl start zoneminder service
Failed to issue method call: Unit service.service failed to load: No such file or directory.
Job for zoneminder.service failed. See 'systemctl status zoneminder.service' and 'journalctl -xn' for details.
COMMAND systemctl status zoneminder.service
zoneminder.service - Video security and surveillance system
Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; disabled)
Active: failed (Result: exit-code) since Wed 2014-04-30 16:39:01 EDT; 36s ago
Process: 3311 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=2)
Apr 30 16:39:01 localhost.localdomain zmpkg.pl[3311]: Bareword "ZM_PATH_LOGS" not allowed while "strict subs" in use at /usr/share/perl5/vendor_perl/ZoneMinder/Logger.pm line 153.
Apr 30 16:39:01 localhost.localdomain zmpkg.pl[3311]: BEGIN not safe after errors--compilation aborted at /usr/share/perl5/vendor_perl/ZoneMinder/Logger.pm line 168.
Apr 30 16:39:01 localhost.localdomain zmpkg.pl[3311]: Compilation failed in require at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 34.
Apr 30 16:39:01 localhost.localdomain zmpkg.pl[3311]: BEGIN failed--compilation aborted at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 34.
"mylog" [readonly] 18L, 1874C 1,1 Top
Re: zoneminder service is disabled
The service is not currently working. You need to start it with .
There is an rpm generously provided by knnniggett here http://www.zoneminder.com/forums/viewto ... =9&t=21400.
Read the readme carefully and then post back here if your still having trouble. You can ignore the part about gnutls as it seems to be working fin with the latest version.
I have it running well on F20 from the rpm above using MariaDB and the latest gnutls.
Cheers,
Jon
sudo zmpkg.pl start
Cheers,
Jon
Well that sounds hopeful, but it also sounds like I should start over. Which not a big deal, but I obviously I need to be very careful.
I did try >sudo zmpkg.pl start
which results in Barewood "ZM_PATH_LOGS" not allowed.
After I reinstall Fedora from the disk again, what else would I need to do before I can proceed with the prerequisites on that page?
Why would you reinstall fedora?
I had some troubles with my paths after trying to install from source which failed and then installing the rpm.
See here for what ended up working for me.
http://www.zoneminder.com/forums/viewto ... 31&t=22112
Cheers,
Jon
Cheers,
Jon
I would reinstall because it sounds a lot simpler than trying to figure out what is wrong. If I don't reinstall, what would be the next step? Do I have to uninstall zoneminder? If so how do I do that?
mysql is required for zoneminder!rodeored wrote:The service will not start - mariadb is enabled but mysqld is not enabled. I wonder if that has something to do with the problem.
http://www.zoneminder.com/wiki/index.ph ... r_Building
Use your package manager of choice, install mysql.If that is the problem how would I fix it
I noticed in the readme it said mysql was recommended as well, but mariadb is working fine here. Running will show maria is running.
rodeo: how did you install what you have now? From source?
#Make uninstall perhaps...
Cheers,
Jon
$ systemctl status mysqld
Cheers,
Jon
I used
yum install zoneminder
I just tried to install zoneminder-1.27.0-1.fc20.src.rpm from knnniggett
It said the software that was trying to be installed is not compatible with this system.
sudo yum remove zoneminder
Once you install the dependencies you need to install zoneminder-1.27.0-1.fc20.x86_64.rpm or zoneminder-1.27.0-1.fc20.i686.rpm depending on if you have a 64 or 32 bit processor.
Cheers,
Jon
Thanks, Jon
I uninstalled zoneminder, and I was able to install the first prerequisite
RPMFusion repository
The second prerequisite, perl-X10-0.03-1.noarch.rpm says
Failed to install file. An unspecified transaction error has occured. More information is available in the detailed report.
There's no indication of where that detailed report might be and I haven't found anything yet googling about it.
