Just wanted to post that I have successfully upgraded my 1.26.5 install on Ubuntu 13.10 to 1.27 via source. I used the new cmake method described in the INSTALL document. The only problem I had was originally missing the trailing dot on the cmake command-line (cmake -C zm_conf.cmake .).
I love the new flat skin! I have a minor issue where the new windows (filters, monitors, etc.) are opening up too small for the new controls, but other than that it looks great.
Successful upgrade from 1.26.5 on Ubuntu 13.10
Re: Successful upgrade from 1.26.5 on Ubuntu 13.10
I am fairly new to zm & linux. I am trying to do a fresh install of zm 1.27 on my ubuntu 12.04. I am stuck at 'create an apache virtual host for zoneminder' in the INSTALL file. What commands do i use exactly to achieve this?
You can read about setting up apache virtual hosts here:
http://httpd.apache.org/docs/2.2/vhosts/
In my Ubuntu installation, I have a zoneminder.conf file under /etc/apache2/conf-available with the following contents:
Then you symlink to that file under /etc/apache2/conf-enabled so apache uses it during startup.
Alias /zm /usr/local/zoneminder
<Directory /usr/local/zoneminder>
php_flag register_globals off
Require all granted
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
You can use the Ubuntu install at:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
You do have to add the delay to : /etc/init.d/zoneminder.
To the package installers version of the file add sleep 15 as shown:
start() {
sleep 15
echo -n "Starting $prog: "
You do not have to patch : /etc/zm/zm.conf
I have done a fresh Ubuntu 12.04 install using the ZM 1.27 from the PPA and have upgraded a running, 15 camera, 12.04 1.26.5 to 1.27 from the PPA. Do an "apt-get dist-upgrade" to get the 1.27.
bb
start() {
sleep 15
bb
Thanks a lot guys...worked out well...
